skracke
(Erik Trapp)
September 20, 2020, 10:26am
1
Hello all awesome people!
Before version 0.115 I used KNX binary sensor to capture DPT 3.007 dimming control from the KNX bus.
I used this to dim/brighten Z-wave lights from KNX buttons around the house.
But now when the significant_bit option has been removed from KNX binary_sensor I don’t know how to do this anymore.
Anyone have any idea on how to solve this with the 0.115 version?
Code I used before version 0.115:
binary_sensor:
- platform: knx
state_address: '1/3/182'
significant_bit: 1
sync_state: false
- platform: knx
significant_bit: 4
sync_state: false
sensors:
master_bedroom_button3_left_dim_up:
value_template: "{{ is_state('binary_sensor.master_bedroom_button3_left_dim_sbit1', 'on') and is_state('binary_sensor.master_bedroom_button3_left_dim_sbit4', 'on') }}"
master_bedroom_button3_left_dim_down:
value_template: "{{ is_state('binary_sensor.master_bedroom_button3_left_dim_sbit1', 'on') and is_state('binary_sensor.master_bedroom_button3_left_dim_sbit4', 'off') }}"
farmio
(Matthias Alphart)
September 20, 2020, 2:04pm
2
Try a “knx_event” instead of the binary sensor - see fire_event in https://www.home-assistant.io/integrations/knx/
skracke
(Erik Trapp)
September 24, 2020, 8:41am
3
Thank you @farmio for pointing me in the right direction.
Here is my solution:
ETS configuration
knx:
fire_event: true
fire_event_filter: ["1/3/180,182"] #send these group addresses to the event bus
expose:
- type: 'binary'
entity_id: 'light.bed_lamp'
address: '1/3/181' #control status LED on KNX button
input_boolean:
master_bedroom_fold3_left_dim_stop:
initial: false
automation:
# Bed lamp on/off
- alias: 'MasterBedroomFold3leftOnOff'
initial_state: 'on'
- platform: event
event_type: knx_event
event_data:
address: '1/3/180'
- service: >
{% if is_state('light.bed_lamp', 'off') %}
light.turn_on
{% else %}
light.turn_off
{% endif %}
entity_id: light.bed_lamp
# Bed lamp brightness control
- alias: 'MasterBedroomFold3leftDimUp'
initial_state: 'on'
- platform: event
event_data:
address: '1/3/182'
data: 9
- service: input_boolean.turn_off
entity_id: input_boolean.master_bedroom_fold3_left_dim_stop
- service: script.turn_on
entity_id: script.bedlight_bright
- alias: 'MasterBedroomFold3leftDimDown'
initial_state: 'on'
- platform: event
event_data:
address: '1/3/182'
data: 1
entity_id: script.bedlight_dim
- alias: 'MasterBedroomFold3leftDimStop'
initial_state: 'on'
- platform: event
event_data:
address: '1/3/182'
data: 0
script:
bedlight_bright:
sequence:
- condition: state
state: 'off'
- service: light.turn_on
brightness_step: 10
entity_id: script.bedlight_bright_pause
bedlight_bright_pause:
sequence:
- condition: state
state: 'off'
- delay:
milliseconds: 400
bedlight_dim:
sequence:
- condition: state
state: 'off'
brightness_step: -10
entity_id: script.bedlight_dim_pause
bedlight_dim_pause:
sequence:
- condition: state
state: 'off'
- delay:
milliseconds: 400
farmio
(Matthias Alphart)
September 24, 2020, 10:20pm
4
Wow, nice!
You may rename the thread to “WTH is it so complicated to dimm a light from a push button?”
