I need to manage different setpoint according to season with several group address configurated in ETS.
For example:
“Actual temperature” on the group address 0/5/42 only in read
“State Summer/Winter” 0/5/45 only in read
“Actual setpoint” 0/5/46 only in read
“Comfort Winter Setpoint” 0/5/47 in read/write
“Standby Winter Setpoint” 0/5/48 in read/write
“Economy Winter Setpoint” 0/5/49 in read/write
“Comfort Summer Setpoint” 0/5/51 in read/write
“Standby Summer Setpoint” 0/5/52 in read/write
“Economy Summer Setpoint” 0/5/53 in read/write
Hi
What actuator uses this configuration? Is there no combined “current setpoint” object you can use for writing the actual selected mode?
Hi, the actuator is VIMAR 02952 Touch Thermostat.
Unfortunately I have not found any object that can act as a combined Setpoint.
Maybe “setpoint shift” can be used for this. Or something can be unlocked in the parameters. Maybe have a look in the manual.
This is a quite unusual setup - I have not seen it in any other actuator. As a workaround you could configure 2 climate entities - one for heating and one for cooling.
