Hi
my heating is connected via knx and mdt actuators
I’m looking for a way to read the status of the valves. I was able to read out all other values normally and also change values, but unfortunately I couldn’t find a way to read out the valve status. Has anyone done this before?
Hi !
You can use command_value_state_address to have it as an extra attribute of your climate entity or just configure a sensor with type: percent for it. What ever you prefer - or both.
this was fast
thank you very much, it seems to be working. but it is now only displayed that the heating is idling. can i also have the percentage values displayed?
edit:
ok, sorry … if i take the sensor, i can at least display it as a new line.
