KNX cover without position state address
Hi Matthias,
I updated to 0.115.2. The cover can now be moved and the up and down symbols in the UI now represent quite good the status. Say you have a cover which drives 12sec. If you run it form open to closed for 6 sec both directions can be used in the UI. This was not the case earlier.
Big thank you.
I was in the impression that the attribute current_position is updates as well to say 50% in the example above. This seems not the case for me. Is this expected behaviour?
Best Regards.
Ralf
It works on my setup. The slider in the UI card moves when I open/close and if I drag it a movement of the cover is initiated.
