I know this isn’t the correct place for this question but this is one guy on here that is genius at this stuff so i’m going to try my luck.
I have 3W dimmable light which is connected to my TheBen dimming actuator, whenever this light turns on it is set to turn on from 1% - 100% over 4 seconds which works on every other light I plug in.
However, with this 3W light there is almost a little spike in the voltage that causes it to turn on at approximately 20% then dim down to 1% then dim all the way back up to 100%.
I have a couple of lights that do something similar. In my case they are actually non-dimmable lights. Have you double checked that your 3W light is in fact dimmable?
I don’t have a Theben KNX dimmer, I have MDT ones myself.
Mine have different modes or dimming curves that can be set depending on the type of light that are connected to them. I’m assuming the Theben would have something similar.
Have you tried playing around with those?
Honestly, can play around with load selection but that is it. I don’t seem to have the dimming curves you’re talking about? Is it something I will need to add?
Could I be using the wrong group object for a light this size?
Its frustrating because the other lights dim so perfectly.
I figured it out! Well not exactly figured out why it happens but resolved it.
The light needs to receive an immediate on command from the actuator when it tries to dim it seems the driver is trying to do its own dimming and the actuator trying to force it to dim another way.
So when I switched the receiving switch order to ‘immediate on’ it works perfectly. No more janky on off.
To have the ability to mark a topic as solved you need to post it in a forum category. I have moved this topic to the Configuration category. You should now be able to mark the post that helped as the solution.
