Greetings,
I’m currently visualizing my house with Home Assistant. I’ve installed a KNX system.
So far, everything’s working very well. Communication with Bluesound, Eaton Easy E4, Miele, etc.
My problem is: When I turn on a light via Home Assistant, the light symbol also appears on the interface. However, this doesn’t respond to the group address from the feedback signal on the actuator’s switching output. However, if the actuator doesn’t switch, the light symbol also appears on the interface when the light is switched.
Is there a way to switch the light symbol on the interface using only the feedback signal from the actuator (which, of course, has its own group address)? It’s correctly linked. I’ve checked it with the diagnostics.
I would be grateful for any help or advice.
Thank you.
Best, Ruprecht, C
