I’m going to build a new smart home setup, and as all the wiring has to be renewed I’m also looking at the options for wired switches, actors etc.
Looking at all the options, KNX is probably the best way to go as you can program all the components to work even if the central unit (Home Assistant for instance) is out of order.
But…why are those components so very expensive compared to other switches and sensors?
Or, maybe I’m just looking on the wrong sites?
I understand that the price of a Sonoff is very low, but a component with KNX that can do the same is 50 times more expensive…at least!
Maybe someone can tell me if looking in the wrong direction, or confirm this…
Cheers,
Leon
