I just started adding the heating systems to my Home Assistant, but it’s not really working as expected. This is how my current configuration looks in ETS:
and this is my config in HA:
the display on the dashboard looks correct, but changing the target temperature in the dashboard has no effect on the actual target temperature. When I also add the “operation address” (1/4/14), the display gets messed up, and instead of showing the temperature, it shows the operation mode. What am I doing wrong?
Also, even though it doesn’t quite fit here, could you help me with another problem? We have a heat pump that cools during the summer. To do this, I manually set the target temperature to 26°C so that the actuators fully open. Can the object “58 Heating/Cooling Output” reverse the control of the actuators? Meaning, if the temperature is above the setpoint, the actuator should open?
