I have a problem getting my heating to work in Home Assistant.
It works perfectly with the glass button from MDT.
In the HA I only get the temperature displayed, but I can’t adjust the temperature.
So that it can be seen on the glass button that the target temperature has changed.
Here is my config maybe someone of you can give me a tip.
I am very glad for any help.
Hi !
Your setpoint_shift_address is 4/0/20 and it’s state_address is 4/0/23
And you don’t seem to have a GO for operation_mode_state_address - maybe you can activate it in parameters or use the same address as for setting (and eventually set the read flag).
