Twours
1
Hi guys,
I have a KNX sensor that I have incorporated into Home Assistant - It is a brightness sensor but it doesn’t always give the correct readings.
It does give readings and update live but its always off by a bit and different even in pitch black
Any help would be great.
farmio
(Matthias Alphart)
2
Hi !
Some more details would be required to help you - like your used configuration and the actual DPT.
Maybe it’s just the same problem as KNX vs. HA: same brightness sensor / address, but different values
