Thanks for responding. I have Siemens 5WG1 146-1AB02 IP Router installed.
Ok, please open a bug report here:
I will think how we can debug this.
Thanks, Iâve opened a bug report.
hi guys
I am thinking about putting this into production at my new home. But I donât see the KNX logo yet at the HA.io webpage, is everything okay with it, ie production ready?
(edited: I saw the merge)
Any developments in KNX support? In my eyes, this is a game changer, the installed base of legacy KNX systems must be significant. Would there be any way to get more developers interested?
HI,
Iâm testing home-assistant in my old house without knx - and itâs really great.
Soon I will start plan my new house with knx.
How good is the knx support? Is everything working? Is it the right choice?
@openha are you using everything with home-assistant and knx?
Thx,
Stefan
My HA installation will go productive with KNX in about 2 months. Right now, itâs only used on a small test pad. However, there are already some users using it in their houses.
@openha my knx-supported house is getting built as we speak, would love to see support for dimmers. Have you got dimmers in your lab or can users (us) be of any assistance in this matter?
Dimmer support will come, but I wonât start with this in the next 2 months.
If you are still interested in testing:
It would be really nice to add HVAC support so operational mode can be controlled (Comfort/Away/Frost protect)
There already is an awesome variety of media player devices available. Thank you for providing this!
In addition I would like to propose to offer support for a media player component for the KNX platform.
I would appreciate to test this component with my trivum RP310 music player. Documentation is available here:
Hi All, Thanks for all your input and work so far, I am looking at an RGB setup have the light working as three separate entities.I have asked the KNX engineer for a list and it big, but I am getting an error
Could not read value of <Light name=âSteamroom REDâ switch=âGroupAddress(â1/6/0â)/GroupAddress(â1/6/3â)/None/Noneâ brightness=âGroupAddress(â1/6/1â)/GroupAddress(â1/6/4â)/None/Noneâ /> 1/6/4
this is a snip of the details i was given
FIRST FIRST.RGB.1/6/5 RGB steam room GREEN ONâOFF EIS 1 âSwitchingâ (1 Bit) Low
FIRST FIRST.RGB.1/6/6 RGB steam room GREEN REG EIS 2 âDimming - controlâ (4 Bit) Low
FIRST FIRST.RGB.1/6/7 RGB steam room GREEN BYTE Uncertain (1 Byte) Low
FIRST FIRST.RGB.1/6/8 RGB steam room GREEN ONâOFF Status EIS 1 âSwitchingâ (1 Bit) Low
FIRST FIRST.RGB.1/6/9 RGB steam room GREEN BYTE Status Uncertain (1 Byte) Low
this is in config Yaml.
light 95:
- platform: knx
address: â1/6/5â
brightness_address: â1/6/6â
state_address: â1/6/7â
brightness_state_address: â1/6/8â
Any ideas of what to put where, I where the last address goes i aint got a clue, Climate controls have also got me confused and it was all in spanish. i can get the heating to turn on/off and the aircon mid low and high that was simple but for some reason i can only turn the temperature down??
climate:
- platform: knx
name: Bedroom temperature
temperature_address: â1/3/0â
setpoint_shift_address: â1/3/2â
setpoint_shift_state_address: â1/3/2â
target_temperature_address: â1/3/2â
operation_mode_address: â1/3/4â
FIRST FIRST.CLIMA.1/3/0 | CLIMA PA DOR.NIĂO TEMP ACTUAL Status | Uncertain (2 Byte) |
FIRST FIRST.CLIMA.1/3/2 | CLIMA PA TEMP DESIRE Status | Uncertain (2 Byte) |
FIRST FIRST.CLIMA.1/3/1 | CLIMA PA TEMP desire status Uncertain (2 Byte) | |
FIRST FIRST.CLIMA.1/3/3 | CLIMA PA Floor heat BUTTON | EIS 1 âSwitchingâ (1 Bit) |
FIRST FIRST.CLIMA.1/3/4 | CLIMA PA Aircon BUTTON | EIS 1 âSwitchingâ (1 Bit) |
FIRST FIRST.CLIMA.1/3/5 | CLIMA PA HOT Status | EIS 1 âSwitchingâ (1 Bit) |
FIRST FIRST.CLIMA.1/3/6 | CLIMA PA COLD Status | EIS 1 âSwitchingâ (1 Bit) |
Translate best i can
Any help would be much appreciated.
D.
