KNX Tunneling Connection Problem
Suddenly my KNX integration stopped working.
I’m having the following error :
“Could not establish connection to KNX/IP interface. ConnectionRefusedError: [Errno 111] Connect call failed (IP, Port)”
I can ping my IP and the username/password of the tunnel connection are good. What happened ?
HA :
  • Core 2023.11.1
  • Supervisor 2023.10.1
  • Operating System 11.1
  • Frontend 20231030.1
Thanks.
power cycle the KNX gateway :wink:
Maybe power cycling helps, but this sounds like a wrong IP address or something like that.
What model is your IP interface?
Thanks, it worked ! Solved the issue by restarting the Hager gateway server.
