KNX warnings
I am having the following warnings in my logs:
2020-01-02 03:28:22 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for circadian_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-02 03:28:22 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-02 03:28:41 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/22
2020-01-02 03:28:41 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/22’ from <Sensor name=“LF Flur EG Treppe” sensor=“None/GroupAddress(“2/5/22”)/None/None” value=“None” unit="%"/>
2020-01-02 03:28:43 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/7
2020-01-02 03:28:43 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/7’ from <Sensor name=“T Flur OG Treppe” sensor=“None/GroupAddress(“2/5/7”)/None/None” value=“None” unit=“°C”/>
2020-01-02 03:28:44 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/23
2020-01-02 03:28:44 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/23’ from <Sensor name=“LF Flur OG Treppe” sensor=“None/GroupAddress(“2/5/23”)/None/None” value=“None” unit="%"/>
2020-01-02 03:28:45 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/25
2020-01-02 03:28:45 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/25’ from <Sensor name=“LF Leo” sensor=“None/GroupAddress(“2/5/25”)/None/None” value=“None” unit="%"/>
2020-01-02 03:28:46 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/26
2020-01-02 03:28:46 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/26’ from <Sensor name=“LF Julian” sensor=“None/GroupAddress(“2/5/26”)/None/None” value=“None” unit="%"/>
2020-01-02 03:28:47 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/27
2020-01-02 03:28:47 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/27’ from <Sensor name=“LF Kinderbad” sensor=“None/GroupAddress(“2/5/27”)/None/None” value=“None” unit="%"/>
2020-01-02 03:28:48 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/29
2020-01-02 03:28:48 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/29’ from <Sensor name=“LF TV” sensor=“None/GroupAddress(“2/5/29”)/None/None” value=“None” unit="%"/>
2020-01-02 03:28:49 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/30
2020-01-02 03:28:49 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/30’ from <Sensor name=“LF Ankleide” sensor=“None/GroupAddress(“2/5/30”)/None/None” value=“None” unit="%"/>
2020-01-02 03:28:51 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/31
2020-01-02 03:28:51 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/31’ from <Sensor name=“LF Eltern” sensor=“None/GroupAddress(“2/5/31”)/None/None” value=“None” unit="%"/>
2020-01-02 03:28:53 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/5
2020-01-02 03:28:53 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/5’ from <Sensor name=“T WEK Wohnen” sensor=“None/GroupAddress(“2/5/5”)/None/None” value=“None” unit=“°C”/>
2020-01-02 03:28:54 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/20
2020-01-02 03:28:54 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/20’ from <Sensor name=“LF WEK Küche” sensor=“None/GroupAddress(“2/5/20”)//60.64” value=“60.64” unit="%"/>
2020-01-02 03:28:55 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time to GroupValueRead request for: 2/5/21
2020-01-02 03:28:55 WARNING (MainThread) [xknx.log] Could not sync group address ‘2/5/21’ from <Sensor name=“LF WEK Wohnen” sensor=“None/GroupAddress(“2/5/21”)/None/None” value=“None” unit="%"/>
This has been like this for about a week, and happens only when HA is restarted.
The circadian integration has been working great for the last couple of months, and I just installed HACS today, so would tend to disregard them as the root of the problem…
It woukd be nice if someone can help me to solve the problem.
Thanks!
The Knx integration tries to read the sensor values on startup and once an hour - it sends a GroupValueRead request to the bus. These errors indicate that there was no answer.
You can try to make your sensor values readable (L-Flag, Filtertables of line couplers) or disable the synchronization by adding sync_state = False to your sensors.
Or you just ignore these errors - incoming telegrams should be handled anyway.
Hi thanks for your answer. The warnings are gone, looks like I forgot to properly configure or program some new sensors…
