New to Home Assistant, and it’s a lot easier to confiure than openHAB!
I’m configuring my Kodi boxes, and have an issue with this:
2017-07-02 19:21:48 ERROR (MainThread) [homeassistant.config] Invalid config for [media_player.kodi]: value is not allowed for dictionary value @ data[‘turn_off_action’]. Got ‘none’. (See ?, line ?). Please check the docs at https://home-assistant.io/components/media_player.kodi/
I have read the documentaion and have this line in my configuration file:
Here is some modified code I have tried with the same error message.
2017-07-03 09:21:15 ERROR (MainThread) [homeassistant.config] Invalid config for [media_player.kodi]: value is not
allowed for dictionary value @ data['turn_off_action']. Got 'none'. (See ?, line ?).
media_player living_kodi:
- platform: kodi
port: 8080
host: ip address
username:
password:
turn_off_action: none
mf_social, I have tried that, and the error does not reappear, however the turn off button is still present in the user interface, and if pressed a pop up appears saying “Turned off xxxxx”, which does nothing to kodi.
If I change the setting to quit then kodi does quit.
In my setup I do not want kodi to quit as it is the front end for a media centre setup.
Am I correct in saying that my syntax and understanding of the available options is correct?
Also should Hass be accepting input from the power button on the UI and giving the message that the device is turned off when it’s default option is ‘none’? I would assume that if it is configured to ‘none’ then the button is not required and the pop up should not appear.
