Hi people,
So I have Kodi setup and working, however unless I have the configuration option enable_websocket: false
set, it fails to update the status unless I restart Home Assistant every time I want it to connect.
What I think is happening is that when Home Assistant starts, it attempts to connect to Kodi at the IP in the config over sockets. If Kodi is up - great - it establishes a connection and works properly. However, after I turn Kodi (and the system that runs it) off then the socket connection is closed.
If I then later come back and turn Kodi on, Home Assistant doesn’t re-establish a connection to the socket. As soon as I restart Home Assistant it reconnects.
I’d really like to use Kodi with enable_websocket: true
as the delay for my automation is not ideal. However, restarting Home Assistant each time I restart Kodi isn’t either.
Is there an option for Home Assistant to attempt to establish a socket connection every X seconds, for example 60, so every minute it’ll see if the Kodi system has been started and connect again.
Thanks for reading,
StarScream
