What is confusing me is when I have both the discovered one and the manually configured one, it shows different information.
This is what shows when it’s playing:
So I don’t understand why they don’t show the same information??? If they did I would just get rid of one of them. It’s nice that the OSMC one shows the last played even when it’s ‘off’
That is rather odd. The immediate thing I notice is the supported_features is different, which may make a difference in presentation in the UI. You need to look at the media_player component to see what these mean.
# Discover some devices automatically
discovery:
enable:
- dlna_dmr
The component doc is here I don’t see any way to add a username and password… In my case it’s on my local network and the last thing I want to do is use auth for Kodi. If I wanted to access it externally I’d just add it to my caddyfile proxy and it’s own subdomain.
The Kodi docs do allow username/password… maybe try that with discovery as well in the dlna_dmr - seems similar format… worth a try?
Adding credentials stops some of the functions working like the image display etc once password is removed it displays as normal with Leia on libreelec
