Check out the link in the post. I use ha-floorplan
A little late, but the EPG/TV Guide is a window, so to bring it up you will need to call the method GUI.ActiveWindow. Something like this will work:
service: kodi.call_method
service_data:
method: GUI.ActivateWindow
window: tvguide
entity_id: media_player.kodi
To exit TV Guide you either select a channel or enter fullscreen PVR again like this:
service_data:
method: GUI.SetFullscreen
fullscreen: true
I’m unable to wrap my head around the keyboard part. What is this “helper” needed here and how do I use it? I really want to add a on screen keyboard to my kodi remote. Can someone dumb down this part pls. Thanks.
An input_text helper, (Input Text - Home Assistant) mine is named “input_text.kodi_buffer” with a max length of 253.
Then i have these cards in the remote panel:
type: horizontal-stack
cards:
- type: custom:text-input-row
entity: input_text.kodi_buffer
- type: button
tap_action:
action: call-service
service: script.turn_on
service_data:
entity_id: script.kr_send_text
show_name: false
icon: mdi:send
icon_height: 30px
Is it possible to use a card like the one in this link to control Kodi? - Lovelace: an awesome modified tv-card with touchpad and haptic feedback
I can get the other buttons to map to my kodi media player but no idea how to get the touchpad part to work.
Heres what I did
created a text input helper called input_text.kodi_buffer. Set max length of 100
created a script called kr_send_text and copied the contents of your script into it. But when i try to save the script it gives the error
Message malformed: not a valid value for dictionary value @ data['sequence'][2]['target']['entity_id']
- I have no idea where to get custom:text-input-row I installed something I found called Lovelace Text Input Row from hacs. Is it the same thing?
Anyway, even after installing that I dont see a card with such a name in the cards list.
Sorry, but I am admittedly a noob so please bear with me. Thank you.
I had the same error when I initially pasted that script in – you need to remove the comment parts of the script (i.e. the // ...
bits)
Thanks for that. Now I have the script working (I can save it)
Still dont know where to get the custom: text-input-row card from
Hi
Can u please share all your code , iam also yatse remote fan
all scripts and lovelace .thx
You can find it on GitHub Multi Layer Remote · ExperienceLovelace/ha-floorplan · Discussion #347 · GitHub
i will check .thx
