Hi!
I’m trying to find a solution for get the TV show art from Kodi instead of thumbnail of the actual video for the entity_picture, like in the Plex integration. I think that would be more useful, because the thumbnail is a random picture about the video, and it’s not really useable for anything…
Is it possible to solve that?
I think the main problem is that the Kodi WebUI using the thumbnail too, and what I see, that the integration get that image too. For movies, this is fine, because the WebUI using the cover, but for series using the episode thumbnail.
For your example, if you change the “thumbnail”,“fanart” to “art”, you will get back all the images which connected to the played item. It’s a good start btw, just need to figure it out how we can use it in the integration.
Örülök, hogy nem csak engem foglalkoztat ez a probléma
You should install (through HACS or manually) the module “Config Template Card” so you can use a template to fetch the url from the sensor and show it in a lovelace card:
