Kodi wait for trigger with kodi_call_method_result
I have a remote to control my kodi that can call HA entities.
Now I have a left and right button on this remote. During navigation I like to use the buttons for left and right as normal.
But during video playback I like to use the left and right button to skip back or forward.
So I have a script asking first the GUI.GetProperties of the current kodi instance. If I get a value back of 12005 I know that a video is playing.
The “wait for a trigger” does not fire probably since it is already too late to receive something over kodi_call_method_result?
Here my script for the left button:
alias: Kodi left button
sequence:
  - service: kodi.call_method
      method: GUI.GetProperties
      properties:
        - currentwindow
      entity_id: media_player.192_168_1_113
  - wait_for_trigger:
      - platform: event
        event_type: kodi_call_method_result
        event_data:
          result_ok: true
          input:
    timeout:
      hours: 0
      minutes: 0
      seconds: 2
      milliseconds: 0
    continue_on_timeout: false
    enabled: true
  - if:
      - condition: template
        value_template: "{{ wait.trigger.event.data.result.currentwindow.id == 12005 }}"
    then:
          entity_id:
            - media_player.192_168_1_113
          method: Player.Seek
          playerid: 1
          value:
            step: smallbackward
    else:
          entity_id:
          method: Input.Left
    enabled: true
mode: single
Why not just use?
 - if:
     - condition: state
       entity_id: media_player.libreelec
       state: 'playing'
Also why are you controlling two media players at the same time?
    then:
          entity_id:
            - media_player.libreelec
thx for the input.
however the video is able to play in the background while you might navigate the menu that’s why I’m looking for the currentwindow.id
And sorry about the two media players I fixed this now.
Ah, that makes sense.
I tried calling the service for my kodi box and monitoring the event. Everything you have looks correct.
Does it work if you use just:
  - wait_for_trigger:
      - platform: event
        event_data:
          result_ok: true
hmm I might have found a solution… Since I’m using HA just for 4 days I’m not sure if this is a “good” way to do it…
The problem was that the when I run the whole script in sequence the kodi_call_method_result is to late to capture the info from kodi.
sequence:
  - parallel:
          properties:
            - currentwindow
          entity_id:
        enabled: true
      - sequence:
          - wait_for_trigger:
              - platform: event
                event_data:
                  result_ok: true
                  input:
            timeout:
              hours: 0
              minutes: 0
              seconds: 2
              milliseconds: 0
            enabled: true
          - if:
            then:
                  entity_id:
                  method: Player.Seek
                  playerid: 1
                  value:
                    step: smallbackward
            else:
                  entity_id:
                  method: Input.Left
            enabled: true
mode: single
