Mactomik
(Mactomik)
April 24, 2024, 1:21pm
22
Played with V300 C8 controller. If anybody need Komfovent external CO2 sensor (connected to C8 terminal pin 3-5 with wire) I managed to get the reading out by adding this sensor:
# Komfovent CO2 air quality sensor
- name: "Komfovent Air CO2 sensor 'ppm"
address: 951
data_type: uint16
scale: 1
unit_of_measurement: "ppm"
state_class: measurement
scan_interval: 30
Is it possible to use komfovent switches in automations? I don’t see them in the UI and in YAML it requires device and entity id? Where should I add them?
Can you please post a screenshot with automation example? What do you write to modbus?
I was able to make it work:
That will put unit to “Away” mode value 1.
Dai1
(Deny)
September 27, 2024, 3:41pm
28
Hello, can you help me integrate it my home assistant?
lnagel
(Lenno Nagel)
March 6, 2025, 8:11pm
29
Hello! I shared this another thread, but it might be an easier way to get Komfovent data into your HA setup
Hello! Many people have shared their yaml configs here earlier, which has been a great help. However I was personally looking for a more out of the box support for the Komfovent devices, so I’ve spent some time to write a full integration for the C6, C6M and C8 modules. This is very easily installable if you have HACS set up. Please keep in mind that this is an early release still, but any help and feedback is appreciated.
[homeassistant]
Contribute to lnagel/hass-komfovent development by creating an account on GitHub.
runnerM
(Marius)
May 29, 2025, 5:12am
31
Finally someone smart has found time. So much thanks Inagel!!!
gabrio79
(Gabrio79)
June 24, 2025, 1:17pm
32
hello, do you have also lovelace setup to share with us?
lnagel
(Lenno Nagel)
June 25, 2025, 12:31pm
33
Try something like this:
- title: Home
sections:
- type: grid
cards:
- type: thermostat
entity: climate.komfovent
features:
- style: icons
type: climate-preset-modes
- type: tile
entity: sensor.komfovent_supply_flow
features_position: bottom
vertical: false
icon: mdi:home-import-outline
- type: tile
entity: sensor.komfovent_extract_flow
vertical: false
icon: mdi:home-export-outline
- type: tile
entity: sensor.komfovent_extract_co2
vertical: false
- type: tile
entity: sensor.komfovent_extract_humidity
vertical: false
- features:
- type: numeric-input
style: buttons
type: tile
entity: number.komfovent_aq_co2_setpoint
vertical: false
hide_state: true
- features:
style: buttons
type: tile
entity: number.komfovent_aq_humidity_setpoint
vertical: false
hide_state: true
- features:
style: buttons
type: tile
entity: number.komfovent_aq_minimum_intensity
vertical: false
hide_state: true
icon: mdi:fan-chevron-down
- features:
style: buttons
type: tile
entity: number.komfovent_aq_maximum_intensity
vertical: false
hide_state: true
icon: mdi:fan-chevron-up
Hi everyone!
I’d like to ask for some help. I have a machine equipped with a C6 controller, into which I installed 2 humidity sensors. How can I retrieve the sensor data through the Modbus connection? Thanks!
