hey,
ive moved over to my rpi4 now, with manual setup on hassbian.
i dont use duckdns or anything yet, only Nabu Casa
config:
konnected:
access_token: !secret konnectedtoken
api_host: http://192.168.0.xx:8123
devices:
- id: !secret konnectedmac
binary_sensors:
- zone: 1
type: door
name: 'Konnected NewTest Zone 1'
- zone: 2
type: door
name: 'Konnected NewTest Zone 2'
- zone: 3
type: door
name: 'Konnected NewTest Zone 3'
- zone: 4
type: door
name: 'Konnected NewTest Zone 4'
- zone: 5
type: door
name: 'Konnected NewTest Zone 5'
- zone: 6
type: door
name: 'Konnected NewTest Zone 6'
logs:
2019-07-02 22:04:54 INFO (MainThread) [homeassistant.setup] Setting up konnected
2019-07-02 22:04:54 DEBUG (MainThread) [homeassistant.components.konnected] Set up binary_sensor Konnected NewTest Zone 1 (initial state: None)
2019-07-02 22:04:54 DEBUG (MainThread) [homeassistant.components.konnected] Set up binary_sensor Konnected NewTest Zone 2 (initial state: None)
2019-07-02 22:04:54 DEBUG (MainThread) [homeassistant.components.konnected] Set up binary_sensor Konnected NewTest Zone 3 (initial state: None)
2019-07-02 22:04:54 DEBUG (MainThread) [homeassistant.components.konnected] Set up binary_sensor Konnected NewTest Zone 4 (initial state: None)
2019-07-02 22:04:54 DEBUG (MainThread) [homeassistant.components.konnected] Set up binary_sensor Konnected NewTest Zone 5 (initial state: None)
2019-07-02 22:04:54 DEBUG (MainThread) [homeassistant.components.konnected] Set up binary_sensor Konnected NewTest Zone 6 (initial state: None)
2019-07-02 22:04:54 DEBUG (MainThread) [homeassistant.components.konnected] Storing data in hass.data[konnected][devices][bcddc23103d0]: {‘binary_sensors’: {1: {‘type’: ‘door’, ‘name’: ‘Konnected NewTest Zone 1’, ‘inverse’: False, ‘state’: None}, 2: {‘type’: ‘door’, ‘name’: ‘Konnected NewTest Zone 2’, ‘inverse’: False, ‘state’: None}, 5: {‘type’: ‘door’, ‘name’: ‘Konnected NewTest Zone 3’, ‘inverse’: False, ‘state’: None}, 6: {‘type’: ‘door’, ‘name’: ‘Konnected NewTest Zone 4’, ‘inverse’: False, ‘state’: None}, 7: {‘type’: ‘door’, ‘name’: ‘Konnected NewTest Zone 5’, ‘inverse’: False, ‘state’: None}, 9: {‘type’: ‘door’, ‘name’: ‘Konnected NewTest Zone 6’, ‘inverse’: False, ‘state’: None}}, ‘sensors’: , ‘switches’: , ‘blink’: True, ‘discovery’: True}
2019-07-02 22:04:54 INFO (MainThread) [homeassistant.setup] Setup of domain konnected took 0.0 seconds.
2019-07-02 22:04:54 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=konnected>
2019-07-02 22:04:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.binary_sensor, platform=konnected, discovered=device_id=bcddc23103d0>
2019-07-02 22:04:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.sensor, platform=konnected, discovered=device_id=bcddc23103d0>
2019-07-02 22:04:55 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.konnected
2019-07-02 22:04:55 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.konnected
2019-07-02 22:04:55 INFO (SyncWorker_18) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-07-02 22:04:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.switch, platform=konnected, discovered=device_id=bcddc23103d0>
2019-07-02 22:05:00 DEBUG (SyncWorker_17) [homeassistant.util.json] JSON file not found: /srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/konnected/.translations/switch.en.json
2019-07-02 22:05:14 INFO (MainThread) [homeassistant.components.discovery] Found new service: konnected {‘host’: ‘192.168.0.xxx’, ‘port’: xxx, ‘ssdp_description’: ‘http://192.168.0.xx:xxx/Device.xml’, ‘name’: ‘Konnected’, ‘model_name’: ‘Konnected’, ‘model_number’: ‘2.2.7’, ‘serial’: ‘xxx’, ‘manufacturer’: ‘konnected.io’, ‘udn’: ‘uuid:8f655392-a778-4fee-97b9-48259183103d0’, ‘upnp_device_type’: ‘urn:schemas-konnected-io:device:Security:1’}
