Konnected binary sensors not working
Hi there
I have upgraded my home assistant to the latest version 0.116.0
Since the update I can’t see the:
Konnected sensors
Rfxtrx covers
In the configuration.yaml the rfxtrx is the same as it was when it was last worked in the older version (nothing has changed). And in the konnected section I did as the UI asked me in the integration.
It is ain’t working
Help
Could you share your configuration? From which Home Assistant version did you upgrade?
Mine isn’t working either, not sure when it was last working however.
My automations for door opening stopped working.
This happened before but I cannot remember how I fixed it.
I am running the latest HA, I have tried rebooting the two Konnected boards.
It may have been a software update from Konnected that fixed it last time. I’m remembering as I type.
Heading down that pathway next.
I spent most of the day on this.
Well, most of the day trying to get my old Mac to act right and flash the units.
The USB never showed up in the flashing tool. I had to give up and revert to a windoze machine.
Successfully flashed the boards and they still are not working correctly.
My binary sensors stopped working as well after updating to 0.116.4 earlier today. I don’t think I saw any breaking changes for the Konnected integration listed. Not sure what’s up.
I tried restarting my Konnected device as well as my HA instance, but no luck. The binary sensors appear, but didn’t update when the zone was triggered. My output zones shows as unavailable.
Strangely, my Konnected integration started working overnight. I can’t seem to find anything in the logs to indicate anything changed. So, everything is working now, but I’m still trying to hunt down what happened. Very strange…
Spent more time on this today, finally…
First removed Konnected integrations in Home Assistant (after screen shooting the setup pages). Couldn’t re-add them because they were not online, wow, duh, after I re-flashed them however long ago it was, they lost the WiFi connection.
Got them back online, Home Assistant discovered them, set them back up, seemed like I had it figured out.
But, no, while HA finds the boards, none of the sensors work. Not in Home Assistant and although they did port back into HomeKit (as new entities) they do not work there either.
I really don’t know where to go from here.
After updating to 0.117.6 my issue is back as well.
