Hello, I’m writing to find out if it is possible to use a Konnected.io board to take my existing prewire sensors in my house and use them to drive the ring alarm system? I.e. instead of buying new wireless sensors, have the Konnected report the status of the sensors to the ring base station itself. Thank you.
Sounds like one of those things you might have to bite the bullet and test out for yourself. You might try writing Konnected to see if you can return the board if it doesn’t work. There isn’t a whole lot of information on the Ring alarm system to connect to home assistant yet let alone third party boards
If you do test it out, be sure to post a follow-up and let us know how it worked. Good luck!
…use a Konnected.io board to take my existing prewire sensors in my house and drive the ring alarm system?
@LightWalk did you try this out? Did it work? Thinking of doing the same thing.
