Konnected integration
With the recent home assistant .106 update I get a notification for discovering a new device which point to the konnected integration (this is already set up in my yaml and working. when clicking on the check it out link, it takes me to the below interface of which it asks for a konnected port… how do I find out the konnected port?
“Please enter the host information for your Konnected Panel.”
Konnected Device IP Address = No problem here
Konnected Device Port = How do I find this out? It is not documented on either the Konnected Website nor the “https://www.home-assistant.io/integrations/konnected/
Thanks in advance
If you know the IP you could do a port scan of the IP and see which port responds. I forget how I found mine but vaguely remember doing a port scan.
My Konnected board failed and I’m waiting on a replacement, but IIRC I got the port from the Konnected mobile app.
Power cycling the konnected and then the hass seemed to force the auto config to work from my previously working yaml.
I was able to use the konnected ios app to check the port and make sure its talking to hass - this is awesome.
Working again, thanks all
I’ve used port 22259 as for konnected web config.
Just a heads up, everyones port is different, it’s purely random (from Nate the dev on their website).
