- go to ‘Integration’
- select a board and click ‘Configure’
- in the ‘Configure I/O’ menu I do NO changes and press ‘Submit’
it says - ‘Unknown error occurred’ …
in the log I got this message:
Logger: aiohttp.server
Source: helpers/data_entry_flow.py:44
First occurred: 6:36:22 PM (2 occurrences)
Last logged: 6:40:12 PM
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 181, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 215, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 118, in post
result = self._prepare_result_json(result)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 44, in _prepare_result_json
data["data_schema"] = voluptuous_serialize.convert(
File "/usr/local/lib/python3.9/site-packages/voluptuous_serialize/__init__.py", line 39, in convert
pval = convert(value, custom_serializer=custom_serializer)
File "/usr/local/lib/python3.9/site-packages/voluptuous_serialize/__init__.py", line 57, in convert
val.update(convert(validator, custom_serializer=custom_serializer))
File "/usr/local/lib/python3.9/site-packages/voluptuous_serialize/__init__.py", line 112, in convert
raise ValueError('Unable to convert schema: {}'.format(schema))
ValueError: Unable to convert schema: <enum 'BinarySensorDeviceClass'>
Other than this the konnected seems working . however I got a continuous ‘open’ state on a motion sensor which was configured long rime ago but disconnected, no wires connected. I wanted reconfigure it but got this error…
Is it the konnected integration issue on HA ?
