After some Ha upgrades I lost Konnected board statuses in HA. At the same time Konnected HA integration seems sends configuration data to with the board; I see sensors are updated on the board via its UI but I do not see any sensors status updates in HA… It looks like the board cannot deliver statuses to HA as it explained here Sensor state callbacks : Konnected Help & Support
I suspect it cannot access the endpoint address (my Hassio installation). Please explain me what is the correct format of the Hassio address I need to put as an endpoint for the board?
It is clear, the board cannot make a call to the endpoint : https://192.168.99.99:8123/api/konnected/device/a9a9a9a9a9a9a although if this call is made from a browser the Konnected integration on HA replies!!! What is wrong with the same call executed by the board???
