I have a Koogeek door sensor that i have paired with the Tuya app. When integrating the Tuya app it pulls in the koogeek as a device, however, the entity is not populated and shows up unsupported. How do I fix this so that I am able to use the sensor?
Troubleshooting steps tried:
-removing and adding back the sensor from home assistant only
-remove and adding back from tuya app
-reset the device and paired with smart life app (same results as prior)
-Tried different networks
I am not seeing any errors in the logs as well.
Any insights as to how this could be happening? It’s also happening to my Tuya camera as well
