Hello i recently purchased a door sensor koogeek branch. Despite i have been trying to find a way to integrate it into HA, i could not find anything. Anyone knows if is there any way to do it? Thanks a lot in advanced
Same here. The DW1 is a nice little homekit compatible sensor but does not show up in hass
It connects via bluetooth. Do I need to do something extra to connect bluetooth devices?
And neither by any cloud service like tuya…we will wait…
I have a couple of the Koogeek Door and Window hooked up through Homekit and my Apple TV.
have a look to “homekit controller” i wrote its configuration but nothing happened…i keep investigating.
i could get the homekit code by adding “homekit controller” en HA configuration.yaml, but despite of trying lots of times i always get the answer that the device has not been paired…
@patapalo
I have my koogeek sensors hooked up through Homekit and my Apple TV.
I made 2 input_booleans
koogeek_achterdeur:
koogeek_voordeur:
I made 4 automations in homekit
And then I made 2 template binary_sensors
sensors:
achterdeur_open:
friendly_name: Achterdeur
device_class: door
value_template: "{{ is_state('input_boolean.koogeek_achterdeur', 'on') }}"
voordeur_open:
friendly_name: Voordeur
device_class: door
value_template: "{{ is_state('input_boolean.koogeek_voordeur', 'on') }}"
This works pretty reliable.
Genius! Works perfectly
Can you explain how are the lines in configuration.yaml?
I answer myself.
before -plataform: template I include bynary_sensor: and It works.
Thanls anyway.
Hi! more than a year later i realized you found the solution. I am trying to do it but no idea. how speaks the door sensor between Homekit and HA? I have followed your steps…(creating input boolean but how did you link this with the sensor itself? Thanks in any case!
did you ever figure this out ?
