Koogeek DW1 Smart Door and Window sensor Bluetooth Homekit integration into Home Assistant
I have several Koogeek DW1 Bluetooth Door and Windows sensors originally designed for Apple Home Homekit and transitioning to Homeassistant, want to have everything integrated through Home Assistant and then back to Apple Home using the Homekit integration.
I managed to integrate several bluetooth Homekit compatible accessories using the true and tried method of first connecting them to Homekit then removing them and then again adding them first to Home Assistant and then back to Apple Home using the Homekit integration but for reason the same trick does not work with the Koogeek DW1 Bluetooth Door and Windows sensor.
Can anybody help me with this? Could anybody do the same before?
Any help would be appreciated!
Did you ever figure this out? I just got HA setup and want to add the Koogeek doorsensors…
