Koogeek Homekit Wifi Smartplug
http://the-gadgeteer.com/2016/06/22/koogeek-homekit-smartplug-review/
This sounds like a very appealing device to replace my crappy weemo massive wall plugs. The power reporting capability would be great sensor as well for home assistant.
bump for this.
I have a few of these plugs and really like them, would like to see them be integrated.
bump fpr this also for me!
I see this topic is started over a year ago… big bump here.
My Koogeek P1EU plugs are useless in Hassio :frowning:
I would also love this addition
koogeek device look great…
Can we have support for koogeek?
+1 on Koogeek support! Their LS1 light strips are really nice! Would love to get HA-integration!
+1, it works with either homekit, alexa and google assistant now, so Home Assistant would make it perfect.
I wonder what is required to get it working. I’m willing to buy one for the developer teams if it helps to get it supported.
+1
Pls support Koogeek!!!
It will be really great if Koogeek products get supported since they are now also available in European standards and support homekit out of the box.
If you search your network with something like Angry IP Scanner you will find a koogeek[some-digits-letters].home.
It has port 80 open, but any request sent giver me back a 404 not found.
Any ideas?
Same here.
Two koogeek devices detected but any GET to its 80 port results in a 404 answer and a “File /url not_found” message.
I wish someone can make them work.
Since koogeek products seem to all work with HomeKit (over wifi?) then the upcoming HomeKit Controller component will control them, see this other thread: Support for control of HomeKit bulbs and switches (testing required!)
Hum. That can be an option, but my current setup is to put all the stuff together in Home Assistant (Philips and Xiaomi) and then use homebridge to add them all unified in Home. I think I will need to twist the idea a little bit (maybe having two Homes) but if it worth I’ll surely do it.
No support yet for this device ?
we need support for koogeek products!
+1 for Support for Koogeek
