Kostal Plenticore integration not working
Where can I find issues on github about specific integrations? I only find pages about the core or about depreciated integrations for Kostal.
I have deleted the integration as it showed some error like “not connected”. I try to reinstall it, but fail.
When I search for it, I first get the message that I cannot add it via the dashboard.
When I follow the link however, I get an error message.
It leads me to:
https://www.home-assistant.io/integrations/kostalplenticore/
The correct link would be:
And there it says:
  • Browse to your Home Assistant instance.
  • Go to Settings > Devices & Services.
  • In the bottom right corner, select the Add Integration button.
  • From the list, select Kostal Plenticore Solar Inverter.
  • Follow the instructions on screen to complete the setup.
Which instructions should I follow here?
I also want to add that I cannot find the exact entry “Kostal Plenticore Solar Inverter” as mentioned, but instead the one you see in the picture called “Kostal Plenticore Inverter”. I do not know if that makes a difference.
If “benutzerdefiniert” actually translates to “custom”, you seem to have a custom component that overrides the builtin one…
Im having the same problem with 2025.1
It seems I’ve using an old but funcional homeassistant-kostalplenticore integration.
And it seems there’s a build in integration but I cant install it, it gives the same error: this integration cant be added from UI.
Did you mnage to overcome?
I tried uninstalling HACS old integration and removed kostal directory. No joy.
