Integrating the Kostal Smart Energy Meter would be great so I could make use of all the data in my two smart meters. More details here: KSEM: smart recording of self-consumption
Not native integration but add this to your configuration.yaml, this is the quick and easy way.
modbus:
- name: "KSEM" #can be anything you want
type: tcp #modbus over tcp
host: 192.168.1.100 #insert your KSEM ip address, eg "host: 192.168.1.100"
port: 502 #insert your KSEM port, eg "port: 502"
sensors:
- name: networkreference_power_ksem #power from grid
slave: 1
device_class: power
state_class: measurement
unit_of_measurement: W
scale: 0.1
address: 0
scan_interval: 10
count: 2
input_type: holding
data_type: uint32
- name: gridfeed_power_ksem #power to grid
slave: 1
device_class: power
scale: 0.1
address: 2
scan_interval: 10
count: 2
input_type: holding
data_type: uint32
- name: networkreference_energy_ksem #total energy from gird
slave: 1
scale: 0.0001
precision: 3
address: 512
scan_interval: 60
count: 4
input_type: holding
data_type: uint64
device_class: energy
state_class: total_increasing
unit_of_measurement: kWh
- name: gridfeed_energy_ksem #total energy to grid
slave: 1
scale: 0.0001
precision: 3
address: 516
scan_interval: 60
count: 4
input_type: holding
data_type: uint64
- name: L1_powerpos_ksem #power sent to grid on L1
slave: 1
device_class: power
scale: 0.1
address: 40
scan_interval: 10
count: 2
input_type: holding
data_type: uint32
- name: L1_powerneg_ksem #power taken to grid on L1
slave: 1
device_class: power
scale: 0.1
address: 42
scan_interval: 10
count: 2
input_type: holding
data_type: uint32
- name: L2_powerpos_ksem #power sent to grid on L2
slave: 1
device_class: power
scale: 0.1
address: 80
scan_interval: 10
count: 2
input_type: holding
data_type: uint32
- name: L2_powerneg_ksem #power taken from grid on L2
slave: 1
device_class: power
scale: 0.1
address: 82
scan_interval: 10
count: 2
input_type: holding
data_type: uint32
- name: L3_powerpos_ksem #power sent to grid on L3
slave: 1
device_class: power
scale: 0.1
address: 120
scan_interval: 10
count: 2
input_type: holding
data_type: uint32
- name: L3_powerneg_ksem #power taken from grid on L3
slave: 1
device_class: power
scale: 0.1
address: 122
scan_interval: 10
count: 2
input_type: holding
data_type: uint32
You can also use GitHub - CJNE/ha-sunspec: Home Assistant customcomponent for SunSpec modbus devices
is there also a power to grid available?
i tried it but i can’t find it
You want to know what is the exact output from house to grid?
The most exact way is to have all the sensors as i described above integrated and L1+L2+L3 pos (powe feed in to grid) and L1+L2+L3 neg (power taken from grid) added up via helper. This is at least how i did it with Plenticore Plus 10/BYD HVM 13.8 and KSEM combo.
but my neg are always 0…
pos are okay.
Whats your setup?
Penticore Plus 5.5 / BYD HVS 7.7 / KSEM
KOSTAL Smart Energy Meter
Gerätetyp hw0200
Software-Version 2.0.0
One or three phase connection to the grid?
Where is your Smart Energy Meter at ‘home consumption’ or at ‘grid connection point’?
what does it mean - or how can i check it?
i have both - home consumption and if i can’t store it or use it at home i sell it to the grid.
Its on home consumption and i cant change it
should i ask to Change
It depends actually how its wired in to your electical panel.
Could be as easy, yes, as changing the setting - or it could require some work to be done in panel by electrician.
Can you check what the smart energy meter is reporting via its web interface?
I can check if you say me where
sorry for that.
Can you tell me the difference between that setting? Why they do that configuratuon?
The cables on the top are connected to the plenti. I batched both Ethernet cable to the smart meter and plenticore
is this picture from current setup? do you have ethernet cable connection to the smart meter front LAN port?
Yes i need to Disconnect it to open it
Is there an Thing Else i could check
I think that since you have KSEM positioned after Plenticore at ‘Home Consumption’ then it wont read negative values, as your house is not providing anything to the grid, only consuming.
You should use this Kostal Plenticore Solar Inverter - Home Assistant
It’ll work even better since you have only one inverter/battery combo. My situation is a bit more complicated as i have multiple inverters
