I would strongly suggest you to check HACS and SunSpec integration
I started using them instead of manual configuration. You can create additional sensors with helper function if needed (to sum output etc).
I have an error with the following code:
- name: L1_powerpos_ksem #power sent to grid on L1
slave: 1
device_class: power
state_class: measurement
unit_of_measurement: W
scale: 0.1
address: 40
scan_interval: 10
count: 2
input_type: holding
data_type: uint64
- name: L1_powerneg_ksem #power taken to grid on L1
slave: 1
device_class: power
scale: 0.1
address: 42
scan_interval: 10
count: 2
input_type: holding
data_type: uint64
- name: L2_powerpos_ksem #power sent to grid on L2
slave: 1
device_class: power
scale: 0.1
address: 80
scan_interval: 10
count: 2
input_type: holding
data_type: uint64
- name: L2_powerneg_ksem #power taken from grid on L2
slave: 1
device_class: power
scale: 0.1
address: 82
scan_interval: 10
count: 2
input_type: holding
data_type: uint64
- name: L3_powerpos_ksem #power sent to grid on L3
slave: 1
device_class: power
scale: 0.1
address: 120
scan_interval: 10
count: 2
input_type: holding
data_type: uint64
- name: L3_powerneg_ksem #power taken from grid on L3
slave: 1
device_class: power
scale: 0.1
address: 122
scan_interval: 10
count: 2
input_type: holding
data_type: uint64
Error:
Konfigurationswarnungen
Invalid config for âmodbusâ at configuration.yaml, line 149: L1_powerpos_ksem: count
illegal with data_type: uint64
âmodbus->0->sensors->6â, got {ânameâ: âL1_powerpos_ksemâ, âslaveâ: 1, âdevice_classâ: âpowerâ, âstate_classâ: âmeasurementâ, âunit_of_measurementâ: âWâ, âscaleâ: 0.1, âaddressâ: 40, âscan_intervalâ: 10, âcountâ: 2, âinput_typeâ: âholdingâ, âdata_typeâ: âuint64â}
Invalid config for âmodbusâ at configuration.yaml, line 161: L1_powerneg_ksem: count
âmodbus->0->sensors->7â, got {ânameâ: âL1_powerneg_ksemâ, âslaveâ: 1, âdevice_classâ: âpowerâ, âstate_classâ: âmeasurementâ, âunit_of_measurementâ: âWâ, âscaleâ: 0.1, âaddressâ: 42, âscan_intervalâ: 10, âcountâ: 2, âinput_typeâ: âholdingâ, âdata_typeâ: âuint64â}
Invalid config for âmodbusâ at configuration.yaml, line 173: L2_powerpos_ksem: count
âmodbus->0->sensors->8â, got {ânameâ: âL2_powerpos_ksemâ, âslaveâ: 1, âdevice_classâ: âpowerâ, âstate_classâ: âmeasurementâ, âunit_of_measurementâ: âWâ, âscaleâ: 0.1, âaddressâ: 80, âscan_intervalâ: 10, âcountâ: 2, âinput_typeâ: âholdingâ, âdata_typeâ: âuint64â}
Invalid config for âmodbusâ at configuration.yaml, line 185: L2_powerneg_ksem: count
âmodbus->0->sensors->9â, got {ânameâ: âL2_powerneg_ksemâ, âslaveâ: 1, âdevice_classâ: âpowerâ, âstate_classâ: âmeasurementâ, âunit_of_measurementâ: âWâ, âscaleâ: 0.1, âaddressâ: 82, âscan_intervalâ: 10, âcountâ: 2, âinput_typeâ: âholdingâ, âdata_typeâ: âuint64â}
Invalid config for âmodbusâ at configuration.yaml, line 197: L3_powerpos_ksem: count
âmodbus->0->sensors->10â, got {ânameâ: âL3_powerpos_ksemâ, âslaveâ: 1, âdevice_classâ: âpowerâ, âstate_classâ: âmeasurementâ, âunit_of_measurementâ: âWâ, âscaleâ: 0.1, âaddressâ: 120, âscan_intervalâ: 10, âcountâ: 2, âinput_typeâ: âholdingâ, âdata_typeâ: âuint64â}
Invalid config for âmodbusâ at configuration.yaml, line 209: L3_powerneg_ksem: count
âmodbus->0->sensors->11â, got {ânameâ: âL3_powerneg_ksemâ, âslaveâ: 1, âdevice_classâ: âpowerâ, âstate_classâ: âmeasurementâ, âunit_of_measurementâ: âWâ, âscaleâ: 0.1, âaddressâ: 122, âscan_intervalâ: 10, âcountâ: 2, âinput_typeâ: âholdingâ, âdata_typeâ: âuint64â}
My data:
modbus:
Where is the error?
The code was at the top of this page.
Thanks for help.
Moin,
just have a look above.
Remove the âcountâ lines from your yaml and it should work.
Ben
Hi NemoN,
Yes, of course. Here they are:
ksem_reg_internal_Energy.yaml
- name: "KSEM Total Active Energy from Grid" # Active energy+
unique_id: kostal_ksem_total_active_energy_from_grid
address: 512
slave: 1
device_class: energy
state_class: total_increasing
unit_of_measurement: Wh
input_type: holding
data_type: uint64
precision: 2
scale: 0.1
scan_interval: 10
- name: "KSEM Total Active Energy to Grid" # Active energy-
unique_id: kostal_ksem_total_active_energy_to_grid
address: 516
slave: 1
input_type: holding
data_type: int64
precision: 2
scale: 0.1
scan_interval: 10"
- name: "KSEM Total Reactive Energy from Grid" # Reactive energy+
unique_id: kostal_ksem_total_reactive_energy_from_grid
address: 520
slave: 1
device_class: reactive_power
unit_of_measurement: var
input_type: holding
data_type: uint64
precision: 2
scale: 0.1
scan_interval: 60
- name: "KSEM Total Reactive Energy to Grid" # Reactive energy-
unique_id: kostal_ksem_total_reactive_energy_to_grid
address: 524
slave: 1
input_type: holding
data_type: int64
precision: 2
scale: 0.1
scan_interval: 60
- name: "KSEM Total Apparent Energy from Grid" # Apparent energy+
unique_id: kostal_ksem_total_apparent_energy_from_grid
address: 544
slave: 1
device_class: apparent_power
unit_of_measurement: VA
input_type: holding
data_type: uint64
precision: 2
scale: 0.1
scan_interval: 60
- name: "KSEM Total Apparent Energy to Grid" # Apparent energy-
unique_id: kostal_ksem_total_apparent_energy_to_grid
address: 548
slave: 1
input_type: holding
data_type: int64
precision: 2
scale: 0.1
scan_interval: 60
- name: "KSEM Active Energy from Grid (L1)" # Active energy+ (L1)
unique_id: kostal_ksem_active_energy_from_grid_L1
address: 592
slave: 1
input_type: holding
data_type: uint64
unit_of_measurement: kWh
scale: 0.0001
precision: 2
scan_interval: 10
- name: "KSEM Active Energy to Grid (L1)" # Active energy- (L1)
unique_id: kostal_ksem_active_energy_to_grid_L1
address: 596
slave: 1
input_type: holding
data_type: uint64
scale: 0.0001
scan_interval: 10
- name: "KSEM Reactive Energy from Grid (L1)" # Reactive energy+ (L1)
unique_id: kostal_ksem_reactive_energy_from_grid_L1
address: 600
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Reactive Energy to Grid (L1)" # Reactive energy- (L1)
unique_id: kostal_ksem_reactive_energy_to_grid_L1
address: 604
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Apparent Energy from Grid (L1)" # Apparent energy+ (L1)
unique_id: kostal_ksem_apparent_energy_from_grid_L1
address: 624
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Apparent Energy to Grid (L1)" # Apparent energy- (L1)
unique_id: kostal_ksem_apparent_energy_to_grid_L1
address: 628
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Active Energy from Grid (L2)" # Active energy+ (L2)
unique_id: kostal_ksem_active_energy_from_grid_L2
address: 672
slave: 1
input_type: holding
data_type: uint64
scale: 0.0001
scan_interval: 10
- name: "KSEM Active Energy to Grid (L2)" # Active energy- (L2)
unique_id: kostal_ksem_active_energy_to_grid_L2
address: 676
slave: 1
input_type: holding
data_type: uint64
scale: 0.0001
scan_interval: 10
- name: "KSEM Reactive Energy from Grid (L2)" # Reactive energy+ (L2)
unique_id: kostal_ksem_reactive_energy_from_grid_L2
address: 680
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Reactive Energy to Grid (L2)" # Reactive energy- (L2)
unique_id: kostal_ksem_reactive_energy_to_grid_L2
address: 684
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Apparent Energy from Grid (L2)" # Apparent energy+ (L2)
unique_id: kostal_ksem_apparent_energy_from_grid_L2
address: 704
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Apparent Energy to Grid (L2)" # Apparent energy- (L2)
unique_id: kostal_ksem_apparent_energy_to_grid_L2
address: 708
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Active Energy from Grid (L3)" # Active energy+ (L3)
unique_id: kostal_ksem_active_energy_from_grid_L3
address: 752
slave: 1
input_type: holding
data_type: uint64
scale: 0.0001
scan_interval: 10
- name: "KSEM Active Energy to Grid (L3)" # Active energy- (L3)
unique_id: kostal_ksem_active_energy_to_grid_L3
address: 756
slave: 1
input_type: holding
data_type: uint64
scale: 0.0001
scan_interval: 10
- name: "KSEM Reactive Energy from Grid (L3)" # Reactive energy+ (L3)
unique_id: kostal_ksem_reactive_energy_from_grid_L3
address: 760
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Reactive Energy to Grid (L3)" # Reactive energy- (L3)
unique_id: kostal_ksem_reactive_energy_to_grid_L3
address: 764
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Apparent Energy from Grid (L3)" # Apparent energy+ (L3)
unique_id: kostal_ksem_apparent_energy_from_grid_L3
address: 784
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
- name: "KSEM Apparent Energy to Grid (L3)" # Apparent energy- (L3)
unique_id: kostal_ksem_apparent_energy_to_grid_L3
address: 788
slave: 1
input_type: holding
data_type: uint64
scale: 0.1
scan_interval: 10
ksem_reg_internal_Instantaneous.yaml
- name: "KSEM Active Power from Grid" # Active power+
unique_id: kostal_ksem_active_power_from_grid
address: 0
slave: 1
device_class: power
scale: 0.1
scan_interval: 10
input_type: holding
data_type: uint32
- name: "KSEM Active Power to Grid" # Active power-
unique_id: kostal_ksem_active_power_to_grid
address: 2
slave: 1
device_class: power
scale: 0.1
scan_interval: 10
input_type: holding
data_type: uint32
- name: "KSEM Reactive Power from Grid" # Reactive power+
unique_id: kostal_ksem_reactive_power_from_grid
address: 4
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Reactive Power to Grid" # Reactive power-
unique_id: kostal_ksem_reactive_power_to_grid
address: 6
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Apparent Power from Grid" # Apparent power+
unique_id: kostal_ksem_apparent_power_from_grid
address: 16
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Apparent Power to Grid" # Apparent power-
unique_id: kostal_ksem_apparent_power_to_grid
address: 18
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Power Factor" # Power factor
unique_id: kostal_ksem_power_factor
address: 24
slave: 1
device_class: power_factor
unit_of_measurement: "%"
scale: 0.1
scan_interval: 60
input_type: holding
data_type: int32
- name: "KSEM Supply Frequency" # Supply frequency
unique_id: kostal_ksem_supply_frequency
address: 26
slave: 1
device_class: frequency
unit_of_measurement: Hz
scale: 0.001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Active Power from Grid (L1)" # Active power+ (L1)
unique_id: kostal_ksem_active_power_from_grid_L1
address: 40
slave: 1
device_class: power
scale: 0.0001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Active Power to Grid (L1)" # Active power- (L1)
unique_id: kostal_ksem_active_power_to_grid_L1
address: 42
slave: 1
device_class: power
scale: 0.0001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Reactive Power from Grid (L1)" # Reactive power+ (L1)
unique_id: kostal_ksem_reactive_power_from_grid_L1
address: 44
slave: 1
scale: 0.0001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Reactive Power to Grid (L1)" # Reactive power- (L1)
unique_id: kostal_ksem_reactive_power_to_grid_L1
address: 46
slave: 1
scale: 0.0001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Apparent Power from Grid (L1)" # Apparent power+ (L1)
unique_id: kostal_ksem_apparent_power_from_grid_L1
address: 56
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Apparent Power to Grid (L1)" # Apparent power- (L1)
unique_id: kostal_ksem_apparent_power_to_grid_L1
address: 58
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Current (L1)" # Current (L1)
unique_id: kostal_ksem_Current_L1
address: 60
slave: 1
device_class: current
unit_of_measurement: A
scale: 0.001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Voltage (L1)" # Voltage (L1)
unique_id: kostal_ksem_Voltage_L1
address: 62
slave: 1
device_class: voltage
scale: 0.001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Power Factor (L1)" # Power factor (L1)
unique_id: kostal_ksem_power_factor_L1
address: 64
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: int32
- name: "KSEM Active Power from Grid (L2)" # Active power+ (L2)
unique_id: kostal_ksem_active_power_from_grid_L2
address: 80
slave: 1
device_class: power
scale: 0.0001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Active Power to Grid (L2)" # Active power- (L2)
unique_id: kostal_ksem_active_power_to_grid_L2
address: 82
slave: 1
device_class: power
scale: 0.0001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Reactive Power from Grid (L2)" # Reactive power+ (L2)
unique_id: kostal_ksem_reactive_power_from_grid_L2
address: 84
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Reactive Power to Grid (L2)" # Reactive power- (L2)
unique_id: kostal_ksem_reactive_power_to_grid_L2
address: 86
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Apparent Power from Grid (L2)" # Apparent power+ (L2)
unique_id: kostal_ksem_apparent_power_from_grid_L2
address: 96
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Apparent Power to Grid (L2)" # Apparent power- (L2)
unique_id: kostal_ksem_apparent_power_to_grid_L2
address: 98
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Current (L2)" # Current (L2)
unique_id: kostal_ksem_Current_L2
address: 100
slave: 1
scale: 0.001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Voltage (L2)" # Voltage (L2)
unique_id: kostal_ksem_Voltage_L2
address: 102
slave: 1
scale: 0.001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Power Factor (L2)" # Power factor (L2)
unique_id: kostal_ksem_power_factor_L2
address: 104
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: int32
- name: "KSEM Active Power from Grid (L3)" # Active power+ (L3)
unique_id: kostal_ksem_active_power_from_grid_L3
address: 120
slave: 1
device_class: power
scale: 0.0001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Active Power to Grid (L3)" # Active power- (L3)
unique_id: kostal_ksem_active_power_to_grid_L3
address: 122
slave: 1
device_class: power
scale: 0.0001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Reactive Power from Grid (L3)" # Reactive power+ (L3)
unique_id: kostal_ksem_reactive_power_from_grid_L3
address: 124
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Reactive Power to Grid (L3)" # Reactive power- (L3)
unique_id: kostal_ksem_reactive_power_to_grid_L3
address: 126
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Apparent Power from Grid (L3)" # Apparent power+ (L3)
unique_id: kostal_ksem_apparent_power_from_grid_L3
address: 136
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Apparent Power to Grid (L3)" # Apparent power- (L3)
unique_id: kostal_ksem_apparent_power_to_grid_L3
address: 138
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Current (L3)" # Current (L3)
unique_id: kostal_ksem_Current_L3
address: 140
slave: 1
scale: 0.001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Voltage (L3)" # Voltage (L3)
unique_id: kostal_ksem_Voltage_L3
address: 142
slave: 1
scale: 0.001
scan_interval: 60
input_type: holding
data_type: uint32
- name: "KSEM Power Factor (L3)" # Power factor (L3)
unique_id: kostal_ksem_power_factor_L3
address: 144
slave: 1
scale: 0.1
scan_interval: 60
input_type: holding
data_type: int32
- name: "KSEM Minimum Active Power to Grid" # (Minimum active power+)*3
unique_id: kostal_ksem_minimum_active_power_from_grid_L3
address: 146
slave: 1
device_class: power
scale: 0.3
scan_interval: 60
input_type: holding
data_type: uint32
ksem_reg_Sunspec.yaml
- name: Total_exported_realenergy_ksem #Total Exported Real Energy
unique_id: ksem_tot_energy_exported
slave: 1
scale: 0.001
address: 40107
scan_interval: 10
# count: 2
input_type: holding
data_type: int32
- name: Total_imported_realenergy_ksem #Total Imported Real Energy
unique_id: ksem_tot_energy_imported
slave: 1
scale: 0.001
address: 40115
scan_interval: 10
# count: 2
input_type: holding
data_type: int32
I have created a subfolder âmodbusâ including those 3 YAML and used a âincludeâ in the configuration.yaml:
- name: "KSEM" #can be anything you want
type: tcp #modbus over tcp
host: 192.168.1.105 #insert your KSEM ip address
port: 502 #insert your KSEM port, eg "port: 502"
sensors: !include_dir_merge_list modbus/
Hope its help.
Laurent
great
Thanks Indiakiloecho!
It seems Kostal is not on the list of certified manufactures (source: Certified Registry - SunSpec Alliance).
Did you manage to include the Kostal KSEM with this HACS integration? I tried but without success.
Thanks!
