matteos1
(Matteo)
January 3, 2022, 8:11pm
1
i bought this module KS0457 keyestudio CCS811 Carbon Dioxide Air Quality Sensor - Keyestudio Wiki , but when i go to insert the code in esphome
i2c:
sda: D0
scl: D1
platform: ccs811
eco2:
name: “CCS811 eCO2 Value”
tvoc:
name: “CCS811 Total Volatile Organic Compound”
address: 0x5A
update_interval: 60s
log it is this :
[21:06:02][I][i2c.arduino:156]: Performing I2C bus recover
[21:06:02][E][i2c.arduino:172]: Recovery failed: SCL is held LOW on the I2C bus
[21:06:04][E][component:112]: Component ccs811.sensor was marked as failed.
and the ic2 bus is not detected.
wemos s1
KS0457_keyestudio_CCS811_Carbon_Dioxide_Air_Quality_Sensor.
i followed this guide
https://esphome.io/components/sensor/ccs811.html
but it doesn’t seem to work.
Input voltage is 5V.
If someone could help me.
thank you
gon
January 5, 2022, 7:22am
2
i had bad experiences running the ccs811 on a wemos d1 because of the clock-stretching, i then moved to an esp32 and esphome.
but i think d0/d1 are a bad choice, try d1/d2 like described here WeMos Mini D1 - Default I2C & SPI pins
matteos1
(Matteo)
January 5, 2022, 4:27pm
4
nothing
the error is on nodemcu
[17:26:56][I][i2c.arduino:156]: Performing I2C bus recovery
[17:26:56][E][i2c.arduino:172]: Recovery failed: SCL is held LOW on the I2C bus
[17:26:56][E][component:112]: Component ccs811.sensor was marked as failed.
matteos1
(Matteo)
January 5, 2022, 4:36pm
5
esphome:
substitutions:
hostname: ‘VOTAIR:’
esp8266:
board: nodemcuv2
Enable logging
logger:
Enable Home Assistant API
api:
ota:
password: “626e3ee26f586edd01aca7253ec33cfa”
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Votair Fallback Hotspot”
password: “KmqpoQJOWO6B”
captive_portal:
web_server:
port: 80
platform: wifi_signal
name: $hostname WiFi Signal
platform: uptime
update_interval: 15s
platform: template
lambda: |-
return id(rssi_value).state * 2 + 200.0;
icon: mdi:wifi
unit_of_measurement: ‘%’
platform: ccs811
eco2:
tvoc:
address: 0x5A
switch:
platform: restart
name: EspHome Node Restart
binary_sensor:
platform: status
text_sensor:
platform: wifi_info
ssid:
name: $hostname WiFi SSID
ip_address:
name: $hostname IP Address
bssid:
name: $hostname Connected BSSID
mac_address:
name: $hostname Mac Wifi Address
scan_results:
name: $hostname Latest Scan Results
platform: version
name: $hostname ESPHome Version
platform: wifi_info
platform: template
name: $hostname Uptime (formatted)
lambda: |-
uint32_t dur = id(uptime_s).state;
int dys = 0;
int hrs = 0;
int mnts = 0;
if (dur > 86399) {
dys = trunc(dur / 86400);
dur = dur - (dys * 86400);
if (dur > 3599) {
hrs = trunc(dur / 3600);
dur = dur - (hrs * 3600);
if (dur > 59) {
mnts = trunc(dur / 60);
dur = dur - (mnts * 60);
char buffer[17];
sprintf(buffer, “%ud %02uh %02um %02us”, dys, hrs, mnts, dur);
return {buffer};
icon: mdi:clock-start
i2c:
sda: D1
scl: D2
this is yaml
matteos1
(Matteo)
January 5, 2022, 8:55pm
6
could you send a scheme o this component and esp32 and yaml with photo?
Thank you
gon
January 6, 2022, 7:36am
7
substitutions:
devicename: combo
deviceplatform: ESP32
deviceboard: espea32
<<: !include common.yaml
i2c:
sda: 21
scl: 22
- platform: dht
pin: 2
model: DHT22
temperature:
filters:
- median
- throttle: 60s
- heartbeat: 60s
humidity:
filters:
- median
- throttle: 60s
- heartbeat: 60s
- platform: ccs811
eco2:
filters:
- median
- throttle: 60s
- heartbeat: 60s
tvoc:
filters:
- median
- throttle: 60s
- heartbeat: 60s
address: 0x5A
baseline: 0x7CBE
temperature: "temperature_dht"
humidity: "humidity_dht"
matteos1
(Matteo)
January 6, 2022, 8:37am
8
do you have a photo with ccs811? i have a wemos esp32
matteos1
(Matteo)
January 6, 2022, 9:53am
9
the log is
[10:52:06][C][ccs811:151]: CCS811
[10:52:06][C][ccs811:152]: Address: 0x5A
[10:52:06][C][ccs811:153]: Update Interval: 60.0s
[10:52:06][C][ccs811:154]: CO2 Sensor ‘eCO2’
[10:52:06][C][ccs811:154]: Device Class: ‘carbon_dioxide’
[10:52:06][C][ccs811:154]: State Class: ‘measurement’
[10:52:06][C][ccs811:154]: Unit of Measurement: ‘ppm’
[10:52:06][C][ccs811:154]: Accuracy Decimals: 0
[10:52:06][C][ccs811:154]: Icon: ‘mdi:molecule-co2’
[10:52:06][C][ccs811:155]: TVOC Sensor ‘TVOC’
[10:52:06][C][ccs811:155]: Device Class: ‘volatile_organic_compounds’
[10:52:06][C][ccs811:155]: State Class: ‘measurement’
[10:52:06][C][ccs811:155]: Unit of Measurement: ‘ppb’
[10:52:06][C][ccs811:155]: Accuracy Decimals: 0
[10:52:06][C][ccs811:155]: Icon: ‘mdi:radiator’
[10:52:06][C][ccs811:160]: Baseline: NOT SET
[10:52:06][W][ccs811:165]: Communication failed! Is the sensor connected?
[10:52:06][C][captive_portal:144]: Captive Portal:
[10:52:06][C][ota:082]: Over-The-Air Updates:
[10:52:06][C][ota:083]: Address: votesp32.local:3232
[10:52:06][C][ota:086]: Using Password.
[10:52:06][C][api:134]: API Server:
[10:52:06][C][api:135]: Address: votesp32.local:6053
[10:52:06][C][api:139]: Using noise encryption: NO
[10:52:06][C][mdns:084]: mDNS:
[10:52:06][C][mdns:085]: Hostname: votesp32
matteos1
(Matteo)
January 6, 2022, 10:43am
11
esphome:
esp32:
board: nodemcu-32s
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "66cefde8fd367f82897835a868150afd"
wifi:
ap:
ssid: "Votesp32 Fallback Hotspot"
password: "NoGblSXsoV4W"
captive_portal:
i2c:
sda: 21
scl: 22
scan: true
- platform: ccs811
eco2:
filters:
- median
- throttle: 60s
- heartbeat: 60s
tvoc:
filters:
- median
- throttle: 60s
- heartbeat: 60s
address: 0x5A
# Example configuration entry
esp32_ble_tracker:
switch:
- platform: gpio
pin: GPIO2
script:
- id: start_led
then:
- switch.turn_on: led
- delay: 1min
- switch.turn_off: led
exposure_notifications:
on_exposure_notification:
then:
- lambda: |
ESP_LOGD("main", "Got notification:");
ESP_LOGD("main", " RPI: %s", hexencode(x.rolling_proximity_identifier).c_str());
ESP_LOGD("main", " RSSI: %d", x.rssi);
# Stop existing timer so that turn_off doesn't get called
- script.stop: start_led
- script.execute: start_led
