Hi, I have a problem with the option trusted_proxy, trusted_networks and bypass login behind a reverse-proxy
My configuration in homeassistant is the next one:
http:
use_x_forwarded_for: true
trusted_proxies:
- 10.42.0.0/16 # Ingress de kubernetes K3s11
- 10.43.0.0/16 # Ingres de Kubernetes K3s13
homeassistant:
external_url: "https://xxx.xxx.xxx.xxx"
auth_providers:
- type: trusted_networks
trusted_networks:
- 10.100.64.26/32
trusted_users:
10.0.64.26:
- 4122be606b4a12d1d67bb12a824asddd218
allow_bypass_login: true
- type: homeassistant
logger:
default: debug
And the traefik configurations is the next one:
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
annotations:
ingress.kubernetes.io/whitelist-x-forwarded-for: "true"
traefik.ingress.kubernetes.io/preserve-host: "true"
traefik.ingress.kubernetes.io/redirect-entry-point: https
traefik.ingress.kubernetes.io/service.passhostheader: "true"
namespace: monitoring
spec:
rules:
- host: xxx.xxxx.xxx
http:
paths:
- backend:
service:
port:
number: 80
path: /
pathType: Prefix
tls:
- hosts:
- xxx.xxxxxx.xx
secretName: xxx-tls
But the logs in Home assistant show me there is no trusted.
23-04-20T14:48:04-04:00 2023-04-20 18:48:04.403 DEBUG (MainThread) [homeassistant.components.http.view] Serving /auth/providers to 10.42.0.1 (auth: False)
2023-04-20T14:48:04-04:00 2023-04-20 18:48:04.673 DEBUG (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow to 10.42.0.1 (auth: False)
2023-04-20T14:48:04-04:00 2023-04-20 18:48:04.677 DEBUG (MainThread) [homeassistant.components.http.view] Serving /manifest.json to 10.42.0.1 (auth: False)
2023-04-20T14:48:06-04:00 2023-04-20 18:48:06.634 DEBUG (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow to 10.42.0.1 (auth: False)
2023-04-20T14:48:07-04:00 2023-04-20 18:48:07.441 DEBUG (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow to 10.42.0.1 (auth: False)
Toda ayuda es bienvenida que voy varios días peleando con este problema
