I found this repo on another thread that dates back to 2017 but the repo was last updated in Mar 2020 - https://github.com/marthoc/kuna and tried installing it on HA VM v 0.113.3 with following steps:
Supervisor --> Add-on-store --> Using the “⋮” on top right side selected --> repository
As you can see in the screenshot, the new repo got added as “unknown” unlike “Ring Livestream” and “HACS” which showed more descriptive headings…but anyhow moving on…
Under integration, “Kuna” cannot be found, I have looked for all combinations of the repo including “unknown” and scrolled through the entire list for integration manually but cannot find this entry.
Also checked the logs but there are no errors.
Please advise if I am doing anything wrong or where to look for possible signs of trouble or bad configurations.
Thanks for your comment!
I noticed in few of the videos “Hass.io” link in the UI between links for “Developers Tools” and “Configuration” in the left side pane.
I installed HA on a VM using the VDI image provided and in my UI I see “Supervisor” link where “Hass.io” was expected, interestingly “Supervisor” link has the same tabs (Dashboard, Add-on Store, Snapshot and System) as Hass.io (see screenshot).
I also noticed following lines in System Tab under Supervisor which may be an error that needs to be resolved as it is specific to the repo I just added,
KTibow, yes you are correct about doing it on Add-on page. This is my 5th day with HA so please excuse my newbie research.
I installed a new version on Raspberry Pi4, the Hass.io tab label has been changed to “Supervisor” but the URL still shows “hass.io” so must be some sort of label upgrade.
I added another custom repo under “Hass.io” for Ring Livestream and after re-start it was visible under “Add-on” tab with the label that was provided in the “repository.json” file of the Ring Livestream repo.
I tried adding “https://github.com/marthoc/kuna” the same way but it did not show up under “Add-on” tab and System log still shows error retrieving this repo, so concluding that something is not configured right with this repo for now.
Thanks for pointing me in the right direction
Pankaj
oooops…
It’s a custom component. Go to HACS, choose Components, and click on the menu in the upper right of HACS. Then choose Custom Repositories, and add it.
It was not working due to my stupidity, I was moving files and folders (according to documentation) using terminal command line. I started Samba Share and dropped the folders using File Explorer and everything worked according to the repo documentation!
@marthocoo I need to tweak the settings I originally set for stream interval and update interval but I cannot access these settings. I’d hate to start from scratch as I have few UI cards as well as automation working around these lights.
Is there a way to change these parameters once integration is up and running?
I have three KUna lights and they are all working fine, I had to make a minor change in a line of code in the source that fixed the problem. Just check the github repo and the thread has the post to fix the code.
