KWH meter S0 config not working
Hi guys,
Let me start with that I’m not a coder. So I use tutorials and hope it works the first time :slight_smile:
I have the following set up:
-esphome with the S0tool code from huizebruin.
-Esp32 connected to a KWH meter LEM022SJ. 400 pulses per kWh (2.5Wh/imp)
-KWH meter to read usage of Tesla wallcharger.
The S0tool is reading KW and KWH. But there is actually nu power been drawn. So it reads false pulses I guess. Imgur: The magic of the Internet
What am I doing wrong?
The code is as following:
select:
:arrow_down: imp/kWh rate :arrow_down:
  • platform: template
    name: “Pulse_rate kWh meter”
    optimistic: true
    options:
    • “2000”
    • “1500”
    • “1000”
    • “500”
    • “400”
    • “100”
      initial_option: “400”
      on_value:
      then:
      • logger.log:
        format: "Chosen option: %s "
        args: [“x.c_str()”]
#------------------------# Kwh meter S0 poort 1 #------------------------#
:arrow_down: kwh meter s0 :arrow_down:
  • platform: pulse_meter
    pin: GPIO14
    icon: “mdi:flash”
    internal_filter: ${impulslengte}
    accuracy_decimals: 3
    unit_of_measurement: ‘kW’
    state_class: measurement
    device_class: power
    filters:
    • lambda: return x * ((60.0 / atoi(id(Select_pulse_rate).state.c_str())));
:arrow_down: Totaal opgebracht :arrow_down:
total:
  unit_of_measurement: 'kWh'
  name: "Totaal opgebracht"
  state_class: total_increasing
  device_class: energy
  icon: "mdi:flash"
  accuracy_decimals: 2
  filters:
    - lambda: return x * ((1.0 / atoi(id(Select_pulse_rate).state.c_str())));
:arrow_down: Kwh meterstand :arrow_down: stand bij benadering
    name: “Actuele meterstand”
    state_class: “total_increasing”
    icon: “mdi:flash”
    update_interval: 1s
    unit_of_measurement: ‘kWh’
    lambda:
    return id(W_opbrengst_totaal).state + id(totalkwhUsage);
Hello Delusional112.
i wrote the code for the esp8266 and specially for the wemos d1 mini.
therefore u cannot put it on a esp32 without modify the code.
