Kwh used, Year-to-date
Hi All,
I would like to display a counter which displays my kWh usage from a set date (ie Jan 1st) till today updated continuously.
Even better would be if it could show the percentage of a set max number.
I have my smart meter integrated, so I get all the data.
The reason I’m asking is; Here in the Netherlands if you go over 2900kWh for the calendar year, you start paying a higher price. So if I can see in June I have used 1450kWh(50%) for example, I know I need to take measures to lower my usage as you use more in the winter months.
Once I know how I can implement the same for the m3 gas usage (max 1200m3).
Can someone point me in the right direction?
Gr,
Daniel
