I tried bringing it inches from the stick, I even did a factory reset.
but even my zwave light switch’s that where labeled secure are not getting added securly eaither.
on a few of the devices i did get a pop up asking for part of a code. i put in the pin listed on the device.
I cant seem to find any youtube videos or documents on this.
I added a Kwikset 910 using z-wave JS configure. Where do I go from here? How do I set user PINS, get notifications?
I’ve been using VeraPlus for years and they’ve finally made it easy to do this. I’m wondering if HA will ever get there.
I am so close. I’ve got my Kwikset 910 paired with HA, Keymaster is installed, the cards are displayed on the Dashboard, HA can control the lock, but look at the Dashboard Card: It says “Entity Not Found.” The PIN Status says “Adding” which means they’re not added yet. (The PIN codes are not the real ones). The PIN Status should say “Connected.”
Thank you! That worked. It took me a moment to find what you were talking about in Configuration>Entities>Test Lock> “Part of the Following Automations.” Not the most intuitive setting.
