I just upgraded my system from the deprecated to to the Z-Wave JS integration. Everything went smoothing except that I didn’t take note of my network key (yeah, I know!). So my Kwikset locks are currently recognized by the system, but I just cannot get them to work. I figured I just need to re-pair them, but nothing has worked. The Z-Wave JS server has a generated network key. I have tried re-pairing the lock, factory reseting the lock, restarting HA, the integration and server after excluding and re-pairing. I have brought the locks to within 6" of the controller when pairing (I’m using a Aotech stick and a Synology/Docker as my server). I just cannot get this to work.
Here is the log. Says it is not secure, but I don’t know why.
2021-09-06T17:33:02.104Z CNTRLR [Node 020] Beginning interview - last completed stage: None
2021-09-06T17:33:02.104Z CNTRLR [Node 020] new node, doing a full interview…
2021-09-06T17:33:02.105Z CNTRLR » [Node 020] querying protocol info…
2021-09-06T17:33:02.164Z CNTRLR « [Node 020] received response for protocol info:
basic device class: Routing Slave
generic device class: Entry Control
specific device class: Secure Keypad Door Lock
node type: Routing End Node
is always listening: false
is frequent listening: 1000ms
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2021-09-06T17:33:02.253Z CNTRLR [Node 020] Interview stage completed: ProtocolInfo
2021-09-06T17:33:02.253Z CNTRLR » [Node 020] querying node info…
2021-09-06T17:33:02.309Z CNTRLR « [Node 020] node info received
supported CCs:
· Z-Wave Plus Info
· Manufacturer Specific
· Device Reset Locally
· Security
· Powerlevel
· Firmware Update Meta Data
controlled CCs:
2021-09-06T17:33:02.312Z CNTRLR [Node 020] Interview stage completed: NodeInfo
2021-09-06T17:33:02.313Z CNTRLR » [Node 020] Querying securely supported commands (S0)…
2021-09-06T17:33:12.474Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:33:12.474Z CNTRLR [Node 020] The node was not granted the S0 security class. Continuing intervie
w non-securely.
2021-09-06T17:33:12.489Z CNTRLR [Node 020] Interviewing Manufacturer Specific…
2021-09-06T17:33:12.490Z CNTRLR » [Node 020] querying manufacturer information…
2021-09-06T17:33:12.544Z CNTRLR « [Node 020] received response for manufacturer information:
manufacturer: Spectrum Brands (0x90)
product type: 0x03
product id: 0x0238
2021-09-06T17:33:12.546Z CNTRLR [Node 020] Interviewing Version…
2021-09-06T17:33:12.546Z CNTRLR » [Node 020] querying the CC version for Version…
2021-09-06T17:33:22.593Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:33:22.594Z CNTRLR [Node 020] CC version query for Version timed out - assuming the node supports
version 1…
2021-09-06T17:33:22.595Z CNTRLR » [Node 020] querying node versions…
2021-09-06T17:33:33.934Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:33:33.936Z CNTRLR » [Node 020] querying CC versions…
2021-09-06T17:33:33.936Z CNTRLR » [Node 020] querying the CC version for Basic…
2021-09-06T17:33:45.197Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:33:45.197Z CNTRLR [Node 020] CC version query for Basic timed out - assuming the node supports v
ersion 1…
2021-09-06T17:33:45.197Z CNTRLR » [Node 020] querying the CC version for Door Lock…
2021-09-06T17:33:56.530Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:33:56.530Z CNTRLR [Node 020] CC version query for Door Lock timed out - assuming the node suppor
ts version 1…
2021-09-06T17:33:56.530Z CNTRLR » [Node 020] querying the CC version for User Code…
2021-09-06T17:34:07.806Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:34:07.808Z CNTRLR [Node 020] CC version query for User Code timed out - assuming the node suppor
ts version 1…
2021-09-06T17:34:07.808Z CNTRLR » [Node 020] querying the CC version for Manufacturer Specific…
2021-09-06T17:34:19.084Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:34:19.085Z CNTRLR [Node 020] CC version query for Manufacturer Specific timed out - assuming the
node supports version 1…
2021-09-06T17:34:19.086Z CNTRLR [Node 020] skipping query for Security (0x98) because max implemented versio
n is 1
2021-09-06T17:34:19.086Z CNTRLR » [Node 020] querying the CC version for Z-Wave Plus Info…
2021-09-06T17:34:30.394Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:34:30.396Z CNTRLR [Node 020] CC version query for Z-Wave Plus Info timed out - assuming the node
supports version 1…
2021-09-06T17:34:30.396Z CNTRLR [Node 020] skipping query for Device Reset Locally (0x5a) because max implem
ented version is 1
2021-09-06T17:34:30.397Z CNTRLR [Node 020] skipping query for Powerlevel (0x73) because max implemented vers
ion is 0
2021-09-06T17:34:30.397Z CNTRLR » [Node 020] querying the CC version for Firmware Update Meta Data…
2021-09-06T17:34:41.670Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:34:41.671Z CNTRLR [Node 020] CC version query for Firmware Update Meta Data timed out - assuming
the node supports version 1…
2021-09-06T17:34:41.821Z CNTRLR [Node 020] Embedded device config loaded
2021-09-06T17:34:41.823Z CNTRLR [Node 020] Interviewing Z-Wave Plus Info…
2021-09-06T17:34:41.824Z CNTRLR » [Node 020] querying Z-Wave+ information…
2021-09-06T17:34:43.108Z CNTRLR « [Node 020] received response for Z-Wave+ information:
Z-Wave+ version: 1
role type: SleepingListeningSlave
node type: Node
installer icon: 0x0300
user icon: 0x0300
2021-09-06T17:34:43.127Z CNTRLR [Node 020] Interviewing Door Lock…
2021-09-06T17:34:43.128Z CNTRLR » [Node 020] requesting lock configuration…
2021-09-06T17:34:53.194Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:34:53.195Z CNTRLR » [Node 020] requesting current lock status…
2021-09-06T17:35:04.499Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:35:04.512Z CNTRLR [Node 020] Interviewing User Code…
2021-09-06T17:35:04.513Z CNTRLR » [Node 020] querying number of user codes…
2021-09-06T17:35:15.801Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:35:15.802Z CNTRLR [Node 020] Querying number of user codes timed out, skipping interview…
2021-09-06T17:35:15.825Z CNTRLR [Node 020] Interview stage completed: CommandClasses
2021-09-06T17:35:15.827Z CNTRLR [Node 020] Interview stage completed: OverwriteConfig
2021-09-06T17:35:15.828Z CNTRLR [Node 020] Interview completed
2021-09-06T17:35:15.829Z CNTRLR [Node 020] The node is ready to be used
2021-09-06T17:38:12.762Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:38:31.514Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-09-06T17:38:49.075Z CNTRLR [Node 020] Timed out while waiting for a response from the node
