Kwikset 912
Totally agree on the docs. Try something like this:
(in configuration.yaml)
    sensors:
      lock_front_door_battery:
        friendly_name: 'Front Door Lock Battery'
        value_template: '{{ states.zwave.front_door_lock.attributes.battery_level }}'
        unit_of_measurement: '%'
        entity_id: zwave.front_door_lock
      lock_front_door_status:
        friendly_name: 'Front Door Lock Status'
        value_template: '{{ states.lock.front_door_lock_locked.attributes.lock_status }}'
        entity_id: lock.front_door_lock_locked
(in groups.yaml:)
lock_card:
  name: Front Door Lock
  entities:
    - lock.front_door_lock_locked
    - sensor.lock_front_door_battery
    - sensor.lock_front_door_status
And then you need to add the lock_card group to one of your view groups. Obviously make sure your entity IDs are right.
To set / clear user codes, you can do that in the Z-Wave Config screen. Select the lock under ‘Nodes’ and the Node User Codes card should appear way down at the bottom of the screen.
