Kwikset 914 integration in Home Assistant 2021.2.3 with Zwave JS
I had 2 kwikset 914 that did not reflect manual unlock changes. Found solutions everywhere, just brig them togheter here. My kwikset were discoverd with new Zwave JS with 2 disabled sensor: one was for the numeric state of the lock. Afert re-enabling them, I was able to use this automation to synch to lock, to the state, matching the manual lock knob state. Thanks to those guys work !
ref : Secure Lock Not Updating Status?
Automation to resynch the lock after a manual change :
# remove this id if you use in configuraiton.yaml.  This code is placed in automations.yaml
- id: 'a4e6882739204d6790dd4f998a01ad01'
  alias: "Synchronisation état de serrure entrée principale"
    platform: state
    entity_id: sensor.smart_code_with_home_connect_technology_alarmtype_2
    - delay:
        seconds: 30
    - service: >
        {%- if ( (trigger.to_state.state == "19") or
                (trigger.to_state.state == "22") or
                (trigger.to_state.state == "25") )
          lock.unlock
        {%- else -%}
          lock.lock
        {% endif %}
      entity_id: lock.smart_code_with_home_connect_technology_current_lock_mode_2
And the other part is to create a sensor template that will use the sensors numeric states of the lock and transform them into text state. Thanks to dukeplc!
# place in configuration.yaml
# Kwickset
    sensors:
      etat_serrure_entree_principale:
        friendly_name: "Etat serrure entrée principale"
        value_template: >-
          {% if is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2', '18') %}
          Vérouillé par clavier
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2', '19') %}
          Dévérouillé par code au clavier
          "{% elif is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2', '112') %}
          Nouveau code usagé ajouté
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2', '162') %}
          Tentative d'accèss en dehors de la cédule
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','22') %}
          Dévérouillé manuellement
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','21') %}
          Vérouillé manuellement
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','27') %}
          Auto vérouillage réussi
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','17') %}
          Vérouillé au clavier, bloqué
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','26') %}
          Auto vérouillage, bloqué
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','23') %}
          Sécurisé par Zwave, bloqué
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','24') %}
          Sécurisé par Zwave, réussi
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','25') %}
          Dévérouillé par Zwave, entièrement rétracté
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','32') %}
          Tous les codes utilisateurs supprmés
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','161') %}
          Échec du code utilisateur au clavier
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','167') %}
          Batterie faible
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','168') %}
          Batterie critique
          {% elif is_state('sensor.smart_code_with_home_connect_technology_alarmlevel_2', '1') and is_state('sensor.smart_code_with_home_connect_technology_alarmtype_2','169') %}
          Batterie trop faible pour opérer
          {% endif %}
###  enjoy translating back to english or look here for the english version : https://www.youtube.com/watch?v=DbxBHlo6KiQ
