Kwikset Convert (Zigbee) doesn't reconnect when Home Assistant restarts
I have a Home Assistant Yellow with a Zigbee (ZHA) network that contains two deadbolts. When I restart Home Assistant (usually after an update), the two deadbolts will not reconnect. I have to enter the reset sequence on the locks in order for them to reconnect. One of them is right next to a repeater (a GE Zigbee light switch). They don’t show as disconnected or unavailable.
Home Assistant Core 2025.1.2 (ongoing since 2024.1 at least)
Device: SMARTCODE_CONVERT_GEN1 by Kwikset
Attached is the error message received when trying to lock/unlock the deadbolt.
Any idea what to look for in the logs, or which logs to post here? Any settings I need to change?
