I Can’t keep the lock node alive for more than 12 hours.
Have already modified options.xml uncommenting the security line
My Z-stick is already mapped as /dev/zwave
configuration file:
zwave:
usb_path: /dev/zwave
config_path: /home/homeassistant/.homeassistant/deps/python_openzwave/ozw_config
network_key: “0xD3, 0x9F, 0xAD, 0x04, 0x1C, 0xEC, 0x76, 0x10, 0xEE, 0xED, 0xB2, 0x0D, 0xB8, 0xF5, 0x6A, 0xEE”
new_entity_ids: true
It seems a distance issue, because when placed closer it works… but they are 6 meters far with behind just one wall. I think they are closer enough…
Heal network nor soft reset make any difference…
Stop and Start network duplicate all devices and works sometimes… not always.
OZW Log:
2017-07-10 15:55:30.688 Always, OpenZwave Version 1.4.2508 Starting Up
2017-07-10 15:55:36.565 Info, Setting Up Provided Network Key for Secure Communications
2017-07-10 15:55:43.350 Info, mgr, Added driver for controller /dev/zwave
2017-07-10 15:55:43.350 Info, Opening controller /dev/zwave
2017-07-10 15:55:43.351 Info, Trying to open serial port /dev/zwave (attempt 1)
2017-07-10 15:55:43.352 Info, Serial port /dev/zwave opened (attempt 1)
2017-07-10 15:55:43.352 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-07-10 15:55:43.353 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-07-10 15:55:43.353 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-07-10 15:55:43.353 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-07-10 15:55:43.353 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-07-10 15:55:43.353 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-07-10 15:55:43.356 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x33, 0x2e, 0x39, 0x35, 0x00, 0x01, 0x99
2017-07-10 15:55:43.356 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2017-07-10 15:55:43.356 Info, contrlr, Static Controller library, version Z-Wave 3.95
2017-07-10 15:55:43.356 Detail, Node045, Expected reply was received
2017-07-10 15:55:43.356 Detail, Node045, Message transaction complete
2017-07-10 15:55:43.357 Detail, contrlr, Removing current message
2017-07-10 15:55:43.357 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-07-10 15:55:43.360 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xc5, 0xbd, 0xd1, 0xc8, 0x01, 0xb6
2017-07-10 15:55:43.360 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xc5bdd1c8. Our node ID = 1
2017-07-10 15:55:43.360 Detail, Node189, Expected reply was received
2017-07-10 15:55:43.360 Detail, Node189, Message transaction complete
2017-07-10 15:55:43.360 Detail, contrlr, Removing current message
2017-07-10 15:55:43.361 Detail,
2017-07-10 15:55:43.361 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-07-10 15:55:43.363 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2017-07-10 15:55:43.363 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2017-07-10 15:55:43.363 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2017-07-10 15:55:43.363 Info, contrlr, The PC controller is a primary controller.
2017-07-10 15:55:43.363 Detail, Node247, Expected reply was received
2017-07-10 15:55:43.363 Detail, Node247, Message transaction complete
2017-07-10 15:55:43.363 Detail, contrlr, Removing current message
2017-07-10 15:55:43.364 Detail,
2017-07-10 15:55:43.364 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-07-10 15:55:43.368 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x00, 0x00, 0x86, 0x01, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfa
2017-07-10 15:55:43.368 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2017-07-10 15:55:43.368 Info, contrlr, Serial API Version: 1.0
2017-07-10 15:55:43.368 Info, contrlr, Manufacturer ID: 0x0086
2017-07-10 15:55:43.368 Info, contrlr, Product Type: 0x0101
2017-07-10 15:55:43.368 Info, contrlr, Product ID: 0x005a
2017-07-10 15:55:43.368 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2017-07-10 15:55:43.368 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2017-07-10 15:55:43.369 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2017-07-10 15:55:43.369 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2017-07-10 15:55:43.369 Detail, Expected reply was received
2017-07-10 15:55:43.369 Detail, Message transaction complete
2017-07-10 15:55:43.369 Detail, contrlr, Removing current message
2017-07-10 15:55:43.369 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-07-10 15:55:43.372 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2017-07-10 15:55:43.372 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2017-07-10 15:55:43.372 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2017-07-10 15:55:43.372 Detail, Node172, Expected reply was received
2017-07-10 15:55:43.372 Detail, Node172, Message transaction complete
2017-07-10 15:55:43.372 Detail, contrlr, Removing current message
2017-07-10 15:55:43.373 Detail,
2017-07-10 15:55:43.373 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2017-07-10 15:55:43.428 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x24, 0xfe, 0x2a, 0xce, 0x92, 0x23, 0x95, 0xa2, 0xf9, 0xfa, 0xc4, 0x4e, 0xc7, 0xbf, 0x1c, 0x1e, 0x30, 0x64, 0xef, 0xd2, 0xbc, 0xcf, 0xd8, 0x36, 0x93, 0xc5, 0x38, 0x66, 0x29, 0x64, 0xc6, 0xe7, 0x3d
2017-07-10 15:55:43.429 Detail,
2017-07-10 15:55:43.429 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2017-07-10 15:55:43.429 Detail, Node032, Expected reply was received
2017-07-10 15:55:43.429 Detail, Node032, Message transaction complete
2017-07-10 15:55:43.429 Detail, contrlr, Removing current message
2017-07-10 15:55:43.429 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2017-07-10 15:55:43.531 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x11, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xd5
2017-07-10 15:55:43.531 Info, mgr, Driver with Home ID of 0xc5bdd1c8 is now ready.
2017-07-10 15:55:43.553 Info, Node005, Value Refresh triggered by CommandClass: COMMAND_CLASS_ALARM, Genre: 1, Instance: 1, Index: 0 for:
2017-07-10 15:55:43.553 Info, Node005, CommandClass: COMMAND_CLASS_DOOR_LOCK, RequestFlags: 0, Instance: 1, Index: 1
2017-07-10 15:55:43.556 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2017-07-10 15:55:43.556 Info, contrlr, Node 001 - Known
2017-07-10 15:55:43.556 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2017-07-10 15:55:43.556 Detail, Node001, QueryStage_CacheLoad
2017-07-10 15:55:43.556 Info, Node001, Node Identity Codes: 0086:0101:005a
2017-07-10 15:55:43.556 Detail, Node001, QueryStage_Associations
2017-07-10 15:55:43.556 Detail, Node001, QueryStage_Neighbors
2017-07-10 15:55:43.556 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2017-07-10 15:55:43.557 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2017-07-10 15:55:43.557 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2017-07-10 15:55:43.557 Info, contrlr, Node 005 - Known
2017-07-10 15:55:43.558 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=0 queryStage=ProtocolInfo live=1
2017-07-10 15:55:43.558 Detail, Node005, QueryStage_ProtocolInfo
2017-07-10 15:55:43.558 Detail, Node005, Queuing (Query) Get Node Protocol Info (Node=5): 0x01, 0x04, 0x00, 0x41, 0x05, 0xbf
2017-07-10 15:55:43.558 Detail, Node005, Queuing (Query) Query Stage Complete (ProtocolInfo)
2017-07-10 15:55:43.558 Detail, Expected reply was received
2017-07-10 15:55:43.558 Detail, Message transaction complete
2017-07-10 15:55:43.558 Detail, contrlr, Removing current message
2017-07-10 15:55:43.558 Detail, Node001, Notification: DriverReady
2017-07-10 15:55:43.569 Detail, Node001, Notification: NodeAdded
2017-07-10 15:55:44.006 Detail, Node001, Notification: NodeProtocolInfo
2017-07-10 15:55:44.012 Detail, Node001, Notification: EssentialNodeQueriesComplete
2017-07-10 15:55:44.017 Detail, Node001, Notification: ValueAdded
2017-07-10 15:55:44.031 Detail, Node001, Notification: NodeNaming
2017-07-10 15:55:44.048 Detail, Node005, Notification: NodeAdded
2017-07-10 15:55:44.083 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.091 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.099 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.109 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.128 Info, Node005, DisablePoll failed - value not on list
2017-07-10 15:55:44.159 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.170 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.193 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.220 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.250 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.271 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.311 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.345 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.355 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.375 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.385 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.401 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.422 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.442 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.459 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.470 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.522 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.535 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.561 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.582 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.608 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.629 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.667 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.683 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.702 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.747 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.769 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.791 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.846 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.872 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.884 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.905 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.938 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.953 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.975 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:44.996 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.018 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.039 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.072 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.088 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.115 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.132 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.153 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.165 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.189 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.230 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.252 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.264 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.278 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.305 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.334 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.354 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.376 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.403 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.438 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.451 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.464 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.474 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.492 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.504 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.517 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.529 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.540 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.555 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.565 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.583 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.601 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.622 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.633 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.647 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.660 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.671 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.681 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.724 Info, Node005, DisablePoll failed - value not on list
2017-07-10 15:55:45.736 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.779 Info, Node005, DisablePoll failed - value not on list
2017-07-10 15:55:45.787 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.796 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.810 Detail, Node005, Notification: Group
2017-07-10 15:55:45.814 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.826 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.836 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.847 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.860 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.871 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.882 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.898 Detail, Node005, Notification: ValueAdded
2017-07-10 15:55:45.910 Detail, Node005, Notification: NodeNaming
2017-07-10 15:55:45.923 Detail,
2017-07-10 15:55:45.923 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2017-07-10 15:55:45.925 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2017-07-10 15:55:45.925 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2017-07-10 15:55:45.925 Detail, Node015, Expected reply was received
2017-07-10 15:55:45.925 Detail, Node015, Message transaction complete
2017-07-10 15:55:45.925 Detail, contrlr, Removing current message
2017-07-10 15:55:45.926 Detail,
2017-07-10 15:55:45.926 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2017-07-10 15:55:45.927 Detail, contrlr, Removing current message
2017-07-10 15:55:45.927 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2017-07-10 15:55:45.932 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x4e
2017-07-10 15:55:45.932 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2017-07-10 15:55:45.933 Info, Node001, Neighbors of this node are:
2017-07-10 15:55:45.933 Info, Node001, Node 5
2017-07-10 15:55:45.933 Detail, Expected reply was received
2017-07-10 15:55:45.933 Detail, Message transaction complete
2017-07-10 15:55:45.933 Detail, Node001, Removing current message
2017-07-10 15:55:45.933 Detail, Node001, Query Stage Complete (Neighbors)
2017-07-10 15:55:45.933 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2017-07-10 15:55:45.933 Detail, Node001, QueryStage_Session
2017-07-10 15:55:45.933 Detail, Node001, QueryStage_Dynamic
2017-07-10 15:55:45.933 Detail, Node001, QueryStage_Configuration
2017-07-10 15:55:45.933 Detail, Node001, QueryStage_Complete
2017-07-10 15:55:45.933 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2017-07-10 15:55:45.934 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2017-07-10 15:55:45.934 Info, Node query processing complete except for sleeping nodes.
2017-07-10 15:55:45.934 Detail, Node001, Notification: NodeQueriesComplete
2017-07-10 15:55:45.939 Detail, contrlr, Notification: AwakeNodesQueried
2017-07-10 15:55:45.944 Detail,
2017-07-10 15:55:45.944 Info, Node005, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=5): 0x01, 0x04, 0x00, 0x41, 0x05, 0xbf
2017-07-10 15:55:45.947 Detail, Node005, Received: 0x01, 0x09, 0x01, 0x41, 0x53, 0xdc, 0x00, 0x04, 0x40, 0x03, 0x7e
2017-07-10 15:55:45.947 Info, Node005, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2017-07-10 15:55:45.947 Info, Node005, Protocol Info for Node 5:
2017-07-10 15:55:45.947 Info, Node005, Listening = false
2017-07-10 15:55:45.947 Info, Node005, Frequent = true
2017-07-10 15:55:45.947 Info, Node005, Beaming = true
2017-07-10 15:55:45.947 Info, Node005, Routing = true
2017-07-10 15:55:45.947 Info, Node005, Max Baud Rate = 40000
2017-07-10 15:55:45.947 Info, Node005, Version = 4
2017-07-10 15:55:45.948 Info, Node005, Security = false
2017-07-10 15:55:47.164 Info, Node005, Basic device class (0x04) - Routing Slave
2017-07-10 15:55:47.164 Info, Node005, Generic device Class (0x40) - Entry Control
2017-07-10 15:55:47.165 Info, Node005, Specific device class (0x03) - Secure Keypad Door Lock
2017-07-10 15:55:47.165 Info, Node005, COMMAND_CLASS_BASIC will be mapped to COMMAND_CLASS_DOOR_LOCK
2017-07-10 15:55:47.165 Info, Node005, Mandatory Command Classes for Node 5:
2017-07-10 15:55:47.165 Info, Node005, COMMAND_CLASS_DOOR_LOCK_LOGGING
2017-07-10 15:55:47.165 Info, Node005, COMMAND_CLASS_USER_CODE
2017-07-10 15:55:47.165 Info, Node005, COMMAND_CLASS_CONFIGURATION
2017-07-10 15:55:47.165 Info, Node005, COMMAND_CLASS_ALARM
2017-07-10 15:55:47.165 Info, Node005, COMMAND_CLASS_MANUFACTURER_SPECIFIC
2017-07-10 15:55:47.165 Info, Node005, COMMAND_CLASS_PROTECTION
2017-07-10 15:55:47.166 Info, Node005, COMMAND_CLASS_BATTERY
2017-07-10 15:55:47.166 Info, Node005, COMMAND_CLASS_ASSOCIATION
2017-07-10 15:55:47.166 Info, Node005, COMMAND_CLASS_VERSION
2017-07-10 15:55:47.166 Info, Node005, COMMAND_CLASS_TIME_PARAMETERS
2017-07-10 15:55:47.166 Info, Node005, COMMAND_CLASS_SECURITY
2017-07-10 15:55:47.166 Info, Node005, Mandatory Command Classes controlled by Node 5:
2017-07-10 15:55:47.166 Info, Node005, None
2017-07-10 15:55:47.166 Detail, Node220, Expected reply was received
2017-07-10 15:55:47.166 Detail, Node220, Message transaction complete
2017-07-10 15:55:47.166 Detail, Node005, Removing current message
2017-07-10 15:55:47.166 Detail, Node005, Notification: NodeProtocolInfo
2017-07-10 15:55:47.175 Detail, Node005, Query Stage Complete (ProtocolInfo)
2017-07-10 15:55:47.175 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2017-07-10 15:55:47.175 Detail, Node005, QueryStage_Probe
2017-07-10 15:55:47.175 Info, Node005, NoOperation::Set - Routing=true
2017-07-10 15:55:47.175 Detail, Node005, Queuing (NoOp) NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xcd
2017-07-10 15:55:47.176 Detail, Node005, Queuing (Query) Query Stage Complete (Probe)
2017-07-10 15:55:47.176 Info, Node005, Sending (NoOp) message (Callback ID=0x0a, Expected Reply=0x13) - NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xcd
2017-07-10 15:55:47.187 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-07-10 15:55:47.187 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2017-07-10 15:55:50.685 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x0a, 0x01, 0x01, 0x5e, 0xbf
2017-07-10 15:55:50.685 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2017-07-10 15:55:50.685 Info, Node005, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2017-07-10 15:55:50.685 Warning, Node005, WARNING: Device is not a sleeping node.
2017-07-10 15:55:50.685 Info, Node005, QueryStageRetry stage Probe requested stage Probe max 3 retries 0 pending 1
2017-07-10 15:55:50.685 Detail, Node001, Expected callbackId was received
2017-07-10 15:55:50.686 Detail, Node001, Expected reply was received
2017-07-10 15:55:50.686 Detail, Node001, Message transaction complete
2017-07-10 15:55:50.686 Detail, Node005, Removing current message
2017-07-10 15:55:50.686 Detail, Node005, Notification: Notification - NoOperation
2017-07-10 15:55:50.693 Detail, Node005, Query Stage Complete (Probe)
2017-07-10 15:55:50.694 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=1 queryStage=Probe live=1
2017-07-10 15:55:50.694 Detail, Node005, QueryStage_Probe
2017-07-10 15:55:50.694 Info, Node005, NoOperation::Set - Routing=true
2017-07-10 15:55:50.694 Detail, Node005, Queuing (NoOp) NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xcc
2017-07-10 15:55:50.694 Detail, Node005, Queuing (Query) Query Stage Complete (Probe)
2017-07-10 15:55:50.694 Info, Node005, Sending (NoOp) message (Callback ID=0x0b, Expected Reply=0x13) - NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xcc
2017-07-10 15:55:50.705 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-07-10 15:55:50.705 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2017-07-10 15:55:54.233 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x0b, 0x01, 0x01, 0x61, 0x81
2017-07-10 15:55:54.233 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2017-07-10 15:55:54.233 Info, Node005, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2017-07-10 15:55:54.233 Warning, Node005, WARNING: Device is not a sleeping node.
2017-07-10 15:55:54.233 Info, Node005, QueryStageRetry stage Probe requested stage Probe max 3 retries 1 pending 1
2017-07-10 15:55:54.233 Detail, Node001, Expected callbackId was received
2017-07-10 15:55:54.233 Detail, Node001, Expected reply was received
2017-07-10 15:55:54.233 Detail, Node001, Message transaction complete
2017-07-10 15:55:54.234 Detail,
2017-07-10 15:55:54.234 Detail, Node005, Removing current message
2017-07-10 15:55:54.234 Detail, Node005, Notification: Notification - NoOperation
2017-07-10 15:55:54.241 Detail, Node005, Query Stage Complete (Probe)
2017-07-10 15:55:54.241 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=2 queryStage=Probe live=1
2017-07-10 15:55:54.241 Detail, Node005, QueryStage_Probe
2017-07-10 15:55:54.241 Info, Node005, NoOperation::Set - Routing=true
2017-07-10 15:55:54.242 Detail, Node005, Queuing (NoOp) NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xcb
2017-07-10 15:55:54.242 Detail, Node005, Queuing (Query) Query Stage Complete (Probe)
2017-07-10 15:55:54.242 Info, Node005, Sending (NoOp) message (Callback ID=0x0c, Expected Reply=0x13) - NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xcb
2017-07-10 15:55:54.253 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-07-10 15:55:54.253 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2017-07-10 15:55:57.766 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x0c, 0x01, 0x01, 0x60, 0x87
2017-07-10 15:55:57.766 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2017-07-10 15:55:57.766 Info, Node005, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2017-07-10 15:55:57.766 Warning, Node005, WARNING: Device is not a sleeping node.
2017-07-10 15:55:57.766 Error, Node005, ERROR: node presumed dead
2017-07-10 15:55:57.766 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=1
2017-07-10 15:55:57.766 Warning, CheckCompletedNodeQueries all=1, deadFound=1 sleepingOnly=1
2017-07-10 15:55:57.766 Info, Node query processing complete except for dead nodes.
2017-07-10 15:55:57.766 Info, Node005, QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
2017-07-10 15:55:57.766 Detail, Node001, Expected callbackId was received
2017-07-10 15:55:57.767 Detail, Node001, Expected reply was received
2017-07-10 15:55:57.767 Detail, Node001, Message transaction complete
2017-07-10 15:55:57.767 Detail, Node005, Removing current message
2017-07-10 15:55:57.767 Detail, Node005, Notification: Notification - NoOperation
2017-07-10 15:55:57.774 Detail, contrlr, Notification: AllNodesQueriedSomeDead
2017-07-10 15:55:57.776 Detail, Node005, Notification: Notification - Node Dead
2017-07-10 15:55:57.783 Detail, Node005, Query Stage Complete (Probe)
2017-07-10 15:55:57.784 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
