Kwikset Smartcode Deadbolt 10 - No entities on pairing with ZHA
I just installed the Kwikset Deadbolt 10 with ZHA and it doesn’t appear to be fully installing. When I get to “Add New Device” it picked it up and says “Interview Complete - Configuring” with some additional information in a blue box. The search finally stops after a few minutes and says “search again” but the blue box remains. Nothing appears to be happening. After leaving it like this for quite a while, I finally bailed out and took a look. The device is installed, but no entities. If I click on reconfigure, I get this:
Any ideas? What am I doing wrong here?
Thanks!!
Bumping this to the top. After messing around with this a little, its still failing similarly. I did get it to install the entities. However, they don’t appear to be fully configured. This is the second one of these I have. The first one installed and configured just fine. Also worth noting that ZHA sees the device on the topology, status is green but no lines to it. The lock is 6 inches from my zigbee router antenna.
I’m a total newbee at YAML. Is it possible to go into the YAML for the first lock that that configured correctly and mirror the settings in the second device? Any guidance would be helpful!!
Thanks!!
Adam
