Kwikset z wave
Yes
Perhaps with the key in place now it will work. I’m trying to get this unknown node removed before repairing.
Thanks for the help!
I got that bad node removed, finally…
I re-added the two door locks, now 11 and 12 which I still don’t understand but whatever.
Here is my OZW data after requesting both doors to lock (they are already locked and have always shown to be unlocked)
2019-04-21 12:29:52.574 Info, Node012, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - True
2019-04-21 12:29:52.574 Info, Node012, Value_Lock::Set - Requesting lock to be Locked
2019-04-21 12:29:52.574 Detail, Node012, Queuing (Send) DoorLockCmd_Set (Node=12): 0x01, 0x0a, 0x00, 0x13, 0x0c, 0x03, 0x62, 0x01, 0xff, 0x25, 0x7c, 0x2c
2019-04-21 12:29:52.574 Detail, Node012, Queuing (Send) DoorLockCmd_Get (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x62, 0x02, 0x25, 0x7d, 0xd3
2019-04-21 12:29:52.574 Info, Node012, Sending (Send) message (Callback ID=0x7c, Expected Reply=0x04) - DoorLockCmd_Set (Node=12): 0x01, 0x0a, 0x00, 0x13, 0x0c, 0x03, 0x62, 0x01, 0xff, 0x25, 0x7c, 0x2c
2019-04-21 12:29:52.585 Detail, Node012, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-04-21 12:29:52.585 Detail, Node012, ZW_SEND_DATA delivered to Z-Wave stack
2019-04-21 12:29:53.733 Detail, Node012, Received: 0x01, 0x07, 0x00, 0x13, 0x7c, 0x00, 0x00, 0x74, 0xe3
2019-04-21 12:29:53.733 Detail, Node012, ZW_SEND_DATA Request with callback ID 0x7c received (expected 0x7c)
2019-04-21 12:29:53.733 Info, Node012, Request RTT 1158 Average Request RTT 1053
2019-04-21 12:29:53.733 Detail, Expected callbackId was received
2019-04-21 12:29:54.067 Info, Node011, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - True
2019-04-21 12:29:54.067 Info, Node011, Value_Lock::Set - Requesting lock to be Locked
2019-04-21 12:29:54.067 Detail, Node011, Queuing (Send) DoorLockCmd_Set (Node=11): 0x01, 0x0a, 0x00, 0x13, 0x0b, 0x03, 0x62, 0x01, 0xff, 0x25, 0x7e, 0x29
2019-04-21 12:29:54.067 Detail, Node011, Queuing (Send) DoorLockCmd_Get (Node=11): 0x01, 0x09, 0x00, 0x13, 0x0b, 0x02, 0x62, 0x02, 0x25, 0x7f, 0xd6
2019-04-21 12:30:02.585 Error, Node012, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-04-21 12:30:02.585 Detail, Node012, Removing current message
2019-04-21 12:30:02.585 Detail, Node012, Notification: Notification - TimeOut
2019-04-21 12:30:02.586 Detail,
2019-04-21 12:30:02.586 Info, Node012, Sending (Send) message (Callback ID=0x7d, Expected Reply=0x04) - DoorLockCmd_Get (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x62, 0x02, 0x25, 0x7d, 0xd3
2019-04-21 12:30:02.594 Detail, Node012, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-04-21 12:30:02.594 Detail, Node012, ZW_SEND_DATA delivered to Z-Wave stack
2019-04-21 12:30:03.831 Detail, Node012, Received: 0x01, 0x07, 0x00, 0x13, 0x7d, 0x00, 0x00, 0x7d, 0xeb
2019-04-21 12:30:03.831 Detail, Node012, ZW_SEND_DATA Request with callback ID 0x7d received (expected 0x7d)
2019-04-21 12:30:03.831 Info, Node012, Request RTT 1244 Average Request RTT 1148
2019-04-21 12:30:03.831 Detail, Expected callbackId was received
2019-04-21 12:30:12.596 Error, Node012, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-04-21 12:30:12.596 Detail, Node012, Removing current message
2019-04-21 12:30:12.596 Detail, Node012, Notification: Notification - TimeOut
2019-04-21 12:30:12.597 Detail,
2019-04-21 12:30:12.597 Info, Node011, Sending (Send) message (Callback ID=0x7e, Expected Reply=0x04) - DoorLockCmd_Set (Node=11): 0x01, 0x0a, 0x00, 0x13, 0x0b, 0x03, 0x62, 0x01, 0xff, 0x25, 0x7e, 0x29
2019-04-21 12:30:12.607 Detail, Node011, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-04-21 12:30:12.607 Detail, Node011, ZW_SEND_DATA delivered to Z-Wave stack
2019-04-21 12:30:13.755 Detail, Node011, Received: 0x01, 0x07, 0x00, 0x13, 0x7e, 0x00, 0x00, 0x73, 0xe6
2019-04-21 12:30:13.755 Detail, Node011, ZW_SEND_DATA Request with callback ID 0x7e received (expected 0x7e)
2019-04-21 12:30:13.755 Info, Node011, Request RTT 1158 Average Request RTT 1051
2019-04-21 12:30:13.755 Detail, Expected callbackId was received
2019-04-21 12:30:22.597 Error, Node011, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-04-21 12:30:22.597 Detail, Node011, Removing current message
2019-04-21 12:30:22.597 Detail, Node011, Notification: Notification - TimeOut
2019-04-21 12:30:22.598 Detail,
2019-04-21 12:30:22.598 Info, Node011, Sending (Send) message (Callback ID=0x7f, Expected Reply=0x04) - DoorLockCmd_Get (Node=11): 0x01, 0x09, 0x00, 0x13, 0x0b, 0x02, 0x62, 0x02, 0x25, 0x7f, 0xd6
2019-04-21 12:30:22.607 Detail, Node011, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-04-21 12:30:22.607 Detail, Node011, ZW_SEND_DATA delivered to Z-Wave stack
2019-04-21 12:30:23.902 Detail, Node011, Received: 0x01, 0x07, 0x00, 0x13, 0x7f, 0x00, 0x00, 0x82, 0x16
2019-04-21 12:30:23.902 Detail, Node011, ZW_SEND_DATA Request with callback ID 0x7f received (expected 0x7f)
2019-04-21 12:30:23.902 Info, Node011, Request RTT 1304 Average Request RTT 1177
2019-04-21 12:30:23.903 Detail, Expected callbackId was received
2019-04-21 12:30:32.601 Error, Node011, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-04-21 12:30:32.602 Detail, Node011, Removing current message
2019-04-21 12:30:32.602 Detail, Node011, Notification: Notification - TimeOut
MAC OS
HA 90.2
AEOTEC Z-Stick
Kwickset Wave door locks (2)
Locks paired securely from the z-wave control panel
Network Key in use but added recently, perhaps delete all z-wave and start fresh with key?
Locks have been removed and added 3 times
node id 11
entity: zwave.kwikset_spectrum_brands_unknown_type_0003_id_0446
node name Kwikset (Spectrum Brands) Unknown: type=0003, id=0446
manufacturer name Kwikset (Spectrum Brands)
product name Unknown: type=0003, id=0446
query stage Complete
is awake true
is ready true
is failed false
is info received true
max baud rate 40000
is zwave plus true
capabilities routing, zwave_plus, beaming, frequent
neighbors 1, 3, 4, 12
sentCnt 10
sentFailed 0
retries 0
receivedCnt 1
receivedDups 0
receivedUnsolicited 0
sentTS 2019-04-21 12:30:22:598
receivedTS 2019-04-20 22:00:23:766
lastRequestRTT 1304
averageRequestRTT 1177
lastResponseRTT 1303
averageResponseRTT 1303
battery level 100
Node 12 (Front door) same
Within that node here is the lock entity that gives me the ability to request lock/unlock
entity: lock.kwikset_spectrum_brands_unknown_type_0003_id_0446_locked
Back Door Lock 14 hours ago
UNLOCK LOCK
Kwikset (Spectrum Brands) Unknown: type=0003, id=0446 Locked
  • Unlocked April 20, 2019, 12:41 PM April 21, 2019, 12:41 PM
    node id 11
    value index 0
    value instance 1
    value id 72057594228277248
Node 12 (Front door) same entity within the node
Any help is appreciated, seems like the same error for both locks “ERROR: Dropping command, expected response not received after 1 attempt(s)” I also still do not have all of the detail as shown several posts above.
Bump… Any help appreciated. Sure wish I could get these working.
Having the same issue here. I have tried removing the node and adding it back in securely, hard resetting the lock, hard exclusion, etc. Nothing I try seems to get the lock to work. I know the lock and z-wave devices work as it used to just fine with Smart Thinks. Here is my log snip-it when I hit unlock.
2019-04-28 19:16:31.240 Info, Node007, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - True
2019-04-28 19:16:31.240 Info, Node007, Value_Lock::Set - Requesting lock to be Locked
2019-04-28 19:16:31.240 Detail, Node007, Queuing (Send) DoorLockCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x62, 0x01, 0xff, 0x25, 0x4f, 0x14
2019-04-28 19:16:31.240 Detail, Node007, Queuing (Send) DoorLockCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x62, 0x02, 0x25, 0x50, 0xf5
2019-04-28 19:16:31.240 Info, Node007, Sending (Send) message (Callback ID=0x4f, Expected Reply=0x04) - DoorLockCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x62, 0x01, 0xff, 0x25, 0x4f, 0x14
2019-04-28 19:16:32.164 Detail, Node007,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-04-28 19:16:32.164 Detail, Node007,   ZW_SEND_DATA delivered to Z-Wave stack
2019-04-28 19:16:33.449 Detail, Node007,   Received: 0x01, 0x07, 0x00, 0x13, 0x4f, 0x00, 0x00, 0x80, 0x24
2019-04-28 19:16:33.449 Detail, Node007,   ZW_SEND_DATA Request with callback ID 0x4f received (expected 0x4f)
2019-04-28 19:16:33.449 Info, Node007, Request RTT 2208 Average Request RTT 2042
2019-04-28 19:16:33.449 Detail,   Expected callbackId was received
2019-04-28 19:16:41.241 Error, Node007, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-04-28 19:16:41.241 Detail, Node007, Removing current message
2019-04-28 19:16:41.241 Detail, Node007, Notification: Notification - TimeOut
2019-04-28 19:16:41.244 Detail,
2019-04-28 19:16:41.244 Info, Node007, Sending (Send) message (Callback ID=0x50, Expected Reply=0x04) - DoorLockCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x62, 0x02, 0x25, 0x50, 0xf5
2019-04-28 19:16:41.525 Detail, Node007,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-04-28 19:16:41.525 Detail, Node007,   ZW_SEND_DATA delivered to Z-Wave stack
2019-04-28 19:16:42.801 Detail, Node007,   Received: 0x01, 0x07, 0x00, 0x13, 0x50, 0x00, 0x00, 0x80, 0x3b
2019-04-28 19:16:42.802 Detail, Node007,   ZW_SEND_DATA Request with callback ID 0x50 received (expected 0x50)
2019-04-28 19:16:42.802 Info, Node007, Request RTT 1557 Average Request RTT 1799
2019-04-28 19:16:42.802 Detail,   Expected callbackId was received
2019-04-28 19:16:51.245 Error, Node007, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-04-28 19:16:51.245 Detail, Node007, Removing current message
2019-04-28 19:16:51.245 Detail, Node007, Notification: Notification - TimeOut
