Kwikset Zwave Locks won't actuate
I have 2 Kwikset 888 Zwave deadbolts. I am trying to get them to lock and unlock over zwave as well as report status. I think I have my zwave security set up properly and the locks do appear after doing the add node secure. However they always state they are unlocked and I cannot lock or unlock them from HA. Any ideas where to start?
Zwave configuration.yaml:
zwave:
usb_path: /dev/ttyUSB0
network_key: “0x49, 0x43, 0x1D, 0xBD, 0x03, 0x6D, 0x9D, 0x8C, 0x39, 0x67, 0x16, 0x82, 0xA8, 0x67, 0xEE, 0x91”
Log when I send the lock command:
2020-06-30 15:38:28.166 Info, Node010, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - True
2020-06-30 15:38:28.166 Info, Node010, Value_Lock::Set - Requesting lock to be Locked
2020-06-30 15:38:28.166 Detail, Node010, Queuing (Send) DoorLockCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x62, 0x01, 0xff, 0x25, 0x39, 0x6f
2020-06-30 15:38:28.166 Detail, Node010, Queuing (Send) DoorLockCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x62, 0x02, 0x25, 0x3a, 0x92
2020-06-30 15:38:28.166 Info, Node010, Sending (Send) message (Callback ID=0x39, Expected Reply=0x04) - DoorLockCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x62, 0x01, 0xff, 0x25, 0x39, 0x6f
2020-06-30 15:38:28.172 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-06-30 15:38:28.172 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2020-06-30 15:38:29.418 Detail, Node010, Received: 0x01, 0x05, 0x00, 0x13, 0x39, 0x00, 0xd0
2020-06-30 15:38:29.418 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x39 received (expected 0x39)
2020-06-30 15:38:29.418 Info, Node010, Request RTT 1251 Average Request RTT 1261
2020-06-30 15:38:29.418 Detail, Expected callbackId was received
2020-06-30 15:38:38.167 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-30 15:38:38.167 Detail, Node010, Removing current message
2020-06-30 15:38:38.167 Detail, Node010, Notification: Notification - TimeOut
2020-06-30 15:38:38.168 Detail,
2020-06-30 15:38:38.168 Info, Node010, Sending (Send) message (Callback ID=0x3a, Expected Reply=0x04) - DoorLockCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x62, 0x02, 0x25, 0x3a, 0x92
2020-06-30 15:38:38.174 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-06-30 15:38:38.174 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2020-06-30 15:38:39.464 Detail, Node010, Received: 0x01, 0x05, 0x00, 0x13, 0x3a, 0x00, 0xd3
2020-06-30 15:38:39.464 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x3a received (expected 0x3a)
2020-06-30 15:38:39.464 Info, Node010, Request RTT 1295 Average Request RTT 1278
2020-06-30 15:38:39.464 Detail, Expected callbackId was received
2020-06-30 15:38:48.169 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-30 15:38:48.169 Detail, Node010, Removing current message
2020-06-30 15:38:48.169 Detail, Node010, Notification: Notification - TimeOut
Did you pair the locks using Add Secure Node ?
Yes I did, though mine only has the option for “Add Node Secure”. I’m assuming that’s the same thing?
Yes same thing, are these the only zwave devices you have?
It doesn’t appear the Network Key was set.
Looking at my config file, can you point out what I did wrong? I was lost on how to make the network key so I just copied an example. I thought that would work.
I have zwave motion lights and switches that work perfectly, but they are not set up secure.
Don’t do that the docs tell you how to generate a key.
You should be configuring the zwave from the integrations menu not in the config file.
I see that command but where do I run it? In the SSH? I will go ahead and delete the zwave from the config file and go back to the integration menu. I had it there before but wanted to try it in the config file to see if it made it work better.
I ran it in the SSH and then manually typed it into a text document. It won’t let you copy from that window for some reason. I pasted into the Zwave integration. I also realized I missed that in the options file, so I removed the commenting from there and added the updated key. I’m assuming I will have to remove the locks from the network and re-add them?
Correct, make sure to use the secure add :slight_smile:
Most of the docs point you at the config files … the thing you linked says to edit the config files.
How do you even enter a key from the integration web page?
You don’t, you enter the config into your configuration.yaml as the docs instruct.
Did you ever get this working?
I also have a Kwikset 888 and cannot get it to actuate.
I’ve tried both the Zwave and new OpenZWave beta and both have the same results.
I have paired the device, add node secure, with the lock ~2" from the base transmitter.
I have a suspicion of what the issue is. These locks were mass produced for Vivint (and possibly other OEMs) and they have anti-theft enabled on them. Connecting it to a Vivint panel it goes through an anti-theft step and then the lock will actuate.
I got it! That was the problem. Also note that it was always showing 100% battery when it was added to the new z-wave network but anti-theft was in effect.
If you re-pair the lock with the Vivint panel then remove it it should disable anti-theft.
I added it back to the Vivint panel and verified it would lock/unlock.
I removed it from the Vivint panel.
I added it back to the Vivint panel - this time it asked me to name the device and prompted me to enable anit-theft which I declined to do.
I added it to my hassio z-wave and now it will lock and unlock.
I am currently running MQTT w/ the new OpenZWave but I suspect it would work with the released zwave as-long-as you update the zwave config files and get the kwikset 888.xml.
On my Vivint panel I touch the … on the Home screen then touch Software Version.
It prompts for the Install PIN which by default is 2203.
Smart Home Devices -> Zwave
I could never figure them out. I ended up returning them.
