Kyo on Home Assistant problem
Hello, my Kyo32 Bentel on Home Assistant configuration it was working ok, my SD is dead and no backup,so I need to configure everything. Home Assistant 2025.03.04 and I’ve done the upgrade with GitHub new files, I have 10 zones but just the first 4 work. Any ideias? Thanks
Hi José, can’t help you with your issue but maybe it might help to share how you have integrated the system.
Regarding ‘no backup’: lesson learned the hard way…
I had many backups, but the PC folder with the backups disappear… Later I can explain.
José, you don’t have to explain it to me. :wink:
Backups are only valuable if they work and you definitely will not be the last person that runs into issues and have no backup to restore.
Also:
I meant: how you integrated the alarm into HA.
You are not sharing many details which make it harder to help you.
I understand, it is the Kyo Bentel repository from Lorenzo de Luca from GitHub, it was working fine, after Home Assistant get 2025.03.04 I have to do a fresh install because the new components policy. Is working, but I have 10 motions sensors and only the first 4 from the yaml is detecting. Meany who install similar, can help me. Thanks
I solved the problem, thanks who try to help me.
