La Marzocco GS/3 & Linea Mini support
You inspired me to try this out on my new Micra. Great idea! Thank you!
@zweckj - possible issue with upcoming HA core release - New HA core Beta causing issues ¡ Issue #26 ¡ zweckj/lamarzocco ¡ GitHub
should be fixed in fixed in v0.13.2b1
Not sure if the version number error i stopping the download?
whoops, had a typo in there. Beta 2 should fix that.
Thanks so much for creating this integration!
I can’t configure it correctly yet. I’m using my email as username and the password I use on the LM app. I either have “failed to connect” or “Invalid authentication”. What do you think am I doing wrong? Should I try to sniff the correct client id and secret instead of using the one reported on GitHub? Thanks so much for your help!
That shouldn’t be necessary anymore, the ones which are now baked into the integration normally work and you don’t need to input any yourself (if you still have the options to enter them on the initial flow you’re on an old version).
Make sure internet access works and there is nothing filtering the traffic like PiHoles.
Thanks so much, looks like I have an old version then. Can you point me to the latest version to try?
Make sure you use my version (GitHub - zweckj/lamarzocco: Interact with your La Marzocco espresso machine) not rccoleman’s (which is still the default in HACS).
Found it and it works beautifully. You guys made a nerd happy today.
@Sc00bs110 can you provide the complete code for t-display ?
thanks!
Not to step on @Sc00bs110 toes, but here is my implementation of his code if it helps. It took me a while to figure out the indenting, so putting it up in case it helps any other novices. “sensor.mr012186_shot_timer” is the home assistant sensor created by the La Marzocco integration. And I changed the color to red to match my black Micra a little better.
esphome:
  friendly_name: shottimer
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "******"
ota:
  password: "******"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: !secret ap_ssid
    password: !secret ap_password
globals:
  type: std::string
  restore_value: no
  initial_value: '"-"'
# Include custom fonts
font:
  - file: 'fonts/GothamRnd-Bold.ttf'
text_sensor:
  - platform: homeassistant
    entity_id: sensor.mr012186_shot_timer
    on_value:
      then:
        - lambda: |-
            id(shot_timer_value) = x;
            id(shottimer_display).update();
# Define colors
color:
  - id: color_text
    red: 100%
    green: 0%
    blue: 0%
    white: 0%
# Pins for Board
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO19
# render on the screen.
display:
  - platform: st7789v
    backlight_pin: GPIO4
    cs_pin: GPIO5
    dc_pin: GPIO16
    reset_pin: GPIO23
    model: TTGO TDisplay 135x240
    rotation: 180°
    lambda: |-
        it.printf(0, 50, id(font2), color_text, "%s", id(shot_timer_value).c_str());
captive_portal:
No toes stood on @dxr :slight_smile:
Am no expert so the more the merrier IMO
Thanks @dxr & @Sc00bs110 for your helps.
I dont where to put the entry on configuration.yaml
I am using esphome to program the t-display and using terminal to edit configuration.yaml
Hi @Mashibb
You can add it anywhere in the configuration.yaml file as long as you don’t have any other text_sensor’s defined, if you do just add it on after the ones you have defined.
If you use the HA File editor, it will display a green tick showing your yaml file is still ok for reboot otherwise check your configuration.yaml file is still working under /developer tools/check configuration before rebooting so as not to have any rebooting problems
I did try to add it. It give out errors for check. I will post the result when i get home.
Thank you for your help.
I was never able to get the text_sensor to compile in the configuration.yaml file. I would get a “Integration error: text_sensor - Integration ‘text_sensor’ not found.” The yaml I have above just uses the integration created one, not a separate text sensor to avoid the issue, but if you figure it out, please post!
I dont get text sensor working also. Changed color to yellow to match my micra
is it possible to get current boiler and steam temp ?
thanks!
Yes, it’s exposed via the current_temperature attribute under the water_heater.<machine_name>_coffee_boiler and water_heater.<machine_name>_steam_boiler entities. You can create template sensors to use them e.g.:
  sensors:
    coffee_machine_brew_boiler_temperature:
      friendly_name: Coffee machine brew boiler temperature
      value_template: "{{ state_attr('water_heater.coffee_machine_coffee_boiler', 'current_temperature') }}"
      icon_template: mdi:thermometer
      unit_of_measurement: "°C"
    coffee_machine_steam_boiler_temperature:
      friendly_name: Coffee machine steam boiler temperature
      value_template: "{{ state_attr('water_heater.coffee_machine_steam_boiler', 'current_temperature') }}"
