La Marzocco GS/3 & Linea Mini support
Would be cool to be able to adjust the boiler temps using the buttons on the ESP32 :slight_smile:
Thanks!! Let me put it in
Should be possible if you add buttons to the GPIO pins and call the water heater service on button press
@zweckj otherwise there are two buttons on the T-Display that I think that you can use in code for actions.
Thanks again for the stellar job, Iā€™m having lots of fun!
I created a couple of automations using a FP2 sensor to turn my LM on when Iā€™m close to it during coffee time. Wonderful.
From today though, I have a serious show stopper. The main switch turns off by itself and the logbook doesnā€™t show anything triggering it. I disabled all automations and itā€™s still happening. When I disable the integration, the issue goes away.
What could I be doing wrong? How can I debug it further? Iā€™m not sure what exactly and why is turning the switch off.
Another minor issue: I donā€™t see the brew timer sensor working.
Thanks for your help!
On a different note (hence the different post), I see an integration with the Acaia lunar scale. Would it open the window of possibility to create our very own brew-by-weight implementation?
Hard to say. Enable debug logging and check your logs to see if you can find anything. Shot timer & brew active sensors only work when you set the host and your HA can reach your machine locally.
Not quite unfortunately. I did not (yet) find a way to stop the brewing without turning the machine off.
Thanks! Iā€™ll look at the debug logs then. Yeah, I was wondering if stopping the brew was exposed.
Iā€™m now getting this problem.
  File "/config/custom_components/lamarzocco/switch.py", line 187, in async_turn_off
    await self.entity_description.control_fn(self._lm_client, False)
  File "/config/custom_components/lamarzocco/lm_client.py", line 99, in set_power
    return await super().set_power(enabled)
  File "/usr/local/lib/python3.11/site-packages/lmcloud/lmcloud.py", line 655, in set_power
    if cloud_ok or bt_ok:
UnboundLocalError: cannot access local variable 'bt_ok' where it is not associated with a value
I tried deleting the integration and set it up again and I still get the error when I turn on/off the machine. Let me know how I can help further. Thanks!
Thatā€™s a bug, but the fact you get there means something went wrong before. Is there anything in the debug logs shortly before that exception?
Does the machine turn on/off after that command?
Thanks Josef. This morning I enabled back the integration to check the logs and itā€™s working perfectly fine. I enabled logs anyway to double check, but nothing is reported. It works. Iā€™ll make sure to report back if it happens again with more logging.
I only have a couple of issues left:
  1. Thereā€™s a big delay (few seconds) between turning on the machine which happens instantly and the machine reporting back to HA that itā€™s been turned on and changing the state of the switch. I do not have a bluetooth gateway just yet (it would solve the issue right?)
  2. I canā€™t seem to be able to make the shot timer work.I set the correct up in the configuration. Itā€™s very minor, but Iā€™d love to change the Nanoleaf light effect when brewing, just for show :slight_smile:
Again, thanks a lot for this work.
Edit: without anything specific I can think of that is triggering, the bt_on error is happening again. And then it was gone after few minutes. The machine does not turn on/off after the command if the error happens.
Yes, Bluetooth would probably solve the speed and not turning on/off problems. My guess is, that thereā€™s something going on with your network, because that would explain both the command issues (it seems like your machine never gets the command from the cloud, thatā€™s why you get to that exception) and your HA instance canā€™t properly connect to your machine (thatā€™s why you donā€™t have the shot timer)
What sort of network problems would cause this? So I have somewhere to look. Machine and HA are on the same subnet and I can ping the machine from HA. Thanks.
Firewalls, PiHoles for example can cause issues
Thanks. I tried to disable pihole, but the issues persist.
Does your machine have a poor WiFi connection? Have you tried removing and re-adding it from your WiFi? If you turn off Bluetooth on your phone and try to turn the machine on/off via the LM app what happens?
Been getting this warning in the logs since the Gateway firmware update
2024-01-13 19:19:22.196 WARNING (MainThread) [lmcloud.lmlocalapi] Unknown websocket message: [{'Boilers': '[{"id":"SteamBoiler","isEnabled":true,"target":131,"current":49},{"id":"CoffeeBoiler1","isEnabled":true,"target":94.5,"current":36}]'}]
Machine has strong WiFi connection. Yeah, I tried removing and readding and the phone apps work reliably. Also, I just noticed the steam boiler always reports 0.
Iā€™d love one day to be able to make the machine turn off by itself after a couple of minutes it pulled a shot if thereā€™s no presence around it :slight_smile:
Yeah 0 ist the fallback there. Your HA definitely canā€™t connect to your machine locally then and apparently LM cloud connection is also flakey then. As to why this happens I got no more ideas unfortunately youā€™re the only one with those issues atm
